Samsung LN52A650A1F - Shorted components PSU: Fix or replace?
  • caphair
    • Nov 2011
    • 1249
    Found the two mains fuses blown, traced to shorted bridge rectifier as well as some mosefts and diodes. Varistors seem fine as don't measure shorted. However I've been reading shorts on random diodes (in circuit) on secondary side, one diode in parallel with relay measures .040v in both directions is that measuring the relay coil resistance?
    Would you replace these or just replace entire board? Friend said he plugged tv into a two prong outlet and then heard a pop after it was on. I'm wondering if bypassing the ground prong caused this or not?
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Samsung LN52A650A1F - Shorted components PSU: Fix or replace?
    Replace.....is my choice.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      In my opinion if you know how to repair it do it buying a replacement might not be as reliable I found this out the hard way, when a used Psu failed with in months so I repaired it by replacing the parts that failed and been working for over a year now.
      • CapLeaker
        Leaking Member
        • 8340
        Depends what the cost of a new PSU and availability is. I mean if you can get a new one for 50$, I'd be replacing this sucker. Unless you want to fix it anyway for educational purpose.
        • caphair
          • Nov 2011
          • 1249
          Found one for $60 on eBay. Also noticed shop Jimmy sells a repair kit for the power mosfets/diodes/fuses that typically go bad in these models for $20 but with shipping comes out to $30.
          I'd like to replace myself for educational purposes but worry I may have missed some shorter smd in correspondence or something.
          • caphair
            • Nov 2011
            • 1249
            I was wondering how do you determine if similar PSU are compatible with model tvs? One I found looks very similar but model numbers slightly off.
            It's listed as a LN52A540P2F
            • CapLeaker
              Leaking Member
              • 8340
              usually SJ tells you that if one PSU from a different TV is a alternate part for yours. Other than that, you would have to do all the work yourself by comparing the mounting, the pin outs, ratings, etc.
                What is the P/N on the board?
                BN44-??????
                  http://www.shopjimmy.com/samsung-bn4...wer-supply.htm
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    A fault in the secondary has probably taken down the components in the primary. You seem to have found most of the faults. To check the diode in parallel with the relay you need to lift one end of the diode otherwise you are reading the relay coil resistance.
                    A home repair I would have though would be worth while.
                      BTW, the LEDs in that video is the dual-LED (two LEDS connected in series into one package).
                        Oops, please disregard my post 11, wrong thread.
                          09-07-2024, 05:50 AM
                          09-06-2024, 11:40 PM
                          09-06-2024, 08:40 PM
                          Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
                          This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                          09-06-2024, 06:20 PM
