Re: Samsung LE46M86BD Constant Restarting
May be something to do with that. The symptoms of this set are a bit different though.
You first turn the tv on and it works fine for about 5-10 mins, afterwards it starts to turn itself off, click and then turn itself back on when power is restored. Unlike other videos and descriptions online of Samsung tvs doing the same thing, the screen flashes off just the same as if you were to pull the plug. It does not go black the same way as turning it off on the front or with remote.
Then what happens is it repeats this on off sequence for up to an hour.
Off>On (for 5-10 seconds, picture shows fine)>off- rinse and repeat.
Eventually it stops and for the rest of the time after its being used it will not turn on and off again.
To simplify it, it only happens when running from cold and only after a few mins of operation.
That being said, it makes little sense why it isn't doing it now. If capacitors are overheating then surely after some time it would start happening or get worse. Not eventually just work after not touching it for a while.
If the capacitors are only functioning properly when *heating up* to a decent level then it makes no sense at all why its not doing it now.
I will use the hairdryer, but since it seems to do it when closer to a cold start I'm not sure it will do anything. Thanks a lot for your help.
View Post
