Samsung TV wrong settings in service menu
  • HellasTechn1
    • Sep 2015
    • 176
    • Greece
    Dear friends, GOOD DAY.
    This is virtually my 1st post in this forum and i am happy to write here with you all.
    Here is the problem i am facing:
    A colleague of mine brought to me a Samsung TV model: LE40A536T1FXXH (from now on called "my tv")
    this tv when turned on would display weird colours for example black background was displayed purple. At first and after reading posts on the internet and in this forum i thought that it would be a Tcon board problem (as15-f) so i ordered one on-line from china. In the meanwhile i came across a similar model tv with the same Tcon board. I thought i should swap cards to see what happes. Both cards didnt work on my tv (same display problem) but worked on the other tv. Bad luck huh ? then i thought that there must be something else wrong with my tv's main board. At that time i had the "brilliant" idea to mess with the service menu so with tv on standby i pressed Info + Menu + Mute + Power on the remote and service menu came up. I started messing with the MODEL and stored in memmory a different code that the original thinking that if that doesnt work i could go back and reset it.
    Now my tv when powered only displays vertical lines and i can no longer acces the service menu. To make matters worse i dont remember neither the factory setting nor the setting i saved.
    On-line i found theese service menu codes
    1) Mute + 1 + 8 + 2 + Power
    2) Display/Info + Menu + Mute + Power (THE ONE USED TO WORK)
    3) Display/Info + P.STD + Mute + Power
    4) P.STD + Help + Sleep + Power
    5) P.STD + Menu + Sleep + Power
    6) Sleep + P.STD + Mute + Power
    Number 1, 2 dont work and for 3,4,5,6 buttons p.std, help and sleep are not present on my remote control.
    Bottom line is that i am freaked out and if o dont come up with a way to fix or restore the tv i may have to pay for a new mainboard myself due to my stupidity...
    That is what happens when you play it smart and mess with things you dont know.
    Thank you !
  • HellasTechn1
    • Sep 2015
    • 176
    • Greece
    Re: Samsung TV wrong settings in service menu
    I forgot to mention that i have tried reseting the eeprom by removing it and reinstalling it but that didnt work obviously because it is not a user settings issue.
    I now wonder if there is a way to hard reset the tv to factory settings from the main board...
    • HellasTechn1
      • Sep 2015
      • 176
      • Greece
      No ideas ? nothing ?
      Is there a way to access service menu from the side buttons ?
      • tibimakai
        • Jan 2012
        • 3680
        You can't find the service manual for this TV?
        Usually, they specify these setting in there.
        • HellasTechn1
          • Sep 2015
          • 176
          • Greece
          THank you tibimakai.
          I have searched and could not find service manual at least not for free
          • tibimakai
            • Jan 2012
            • 3680
            I see one, but have not downloaded it at elektrotanya. Get Manual, will appear after like 30 seconds below the picture.
            • HellasTechn1
              • Sep 2015
              • 176
              • Greece
              I will look for it. Thanks. I will get back with more details when i find out something.
              • freakaftr8
                • Oct 2012
                • 3743
                Have you attemped to try different panel settings in the service menu? Maybe someone knew how to access and messed things up .I've seen it before.
                Sounds like LVDS settings.
                • HellasTechn1
                  • Sep 2015
                  • 176
                  • Greece
                  I am not sure if the original problem was jut a wrong setting. Now the way things are i can not acces service menu and restore model to it's original value so the panel can work.
                  • Alastair E
                    Chief Womble
                    • Mar 2013
                    • 1963
                    • U.K.
                    Personally I think Either the LCD Display Panel (Most Likely, seeing Samsung) OR The Mainboard was faulty originally.
                    Now--Both the Mainboard, --now messed up-- and possibly the display is faulty.
                    Why--Originally, didn't you try the Mainboard from the Other set (That you said were same) in this one--instead of potching with settings?
                    Highly unlikely settings change by themselves, so little is gained by messing with them in the first place--Except disasters like this. A Little Knowledge is a Dangerous thing as you have discovered!
                    You Could try downloading the F/W for that exact set from Samsung and updating--but with no picture to work with, this could be difficult/impossible without pulling the Mem-chip and re-writing externally....
                    TELEFIX
                    • HellasTechn1
                      • Sep 2015
                      • 176
                      • Greece
                      I did swap mainboards and it works perfect so psu, panel and tcon are fine. Mainboard is in deed the problem and i just made it worse.
                      What is the F/W ?
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        Firmware you maybe able to get it from the samsung site usually have to download it to a usb stick.
                        • victor_cj
                          • May 2015
                          • 90
                          • Romania
                          I found some pictures of the service menu, enter again blind and fix it.
                          The art of fighting without fighting
                          • HellasTechn1
                            • Sep 2015
                            • 176
                            • Greece
                            No luck so far. I cant make it to Service Menu.
                            • tibimakai
                              • Jan 2012
                              • 3680
                              There is no EEPROM reset procedure for this model?
                              • glutton4punishment
                                Samsung monitor Installed 1 cap wrong, now menu button dead, "no signal detected" msg
                                by glutton4punishment
                                Samsung synchmaster 226BW.
                                Before I replaced 5 caps, the screen was dim.
                                Sometimes it wouldn't turn on.
                                I opened it up, and found 4 bad caps in the pwr supply section.
                                I unfortunately installee one backwards, i.e. wrong polarity.
                                When I turned it on, I head a loud pop, and I quickly shut it off.
                                The replaced caps are 3 860uF 25V's, and 1 330u 35V.
                                One of the 860uF blew.
                                I didn't have another 860uF at home, so I tried it with a 1000uF 35V cap (I remember the reading of the 1k uF cap was close...
                                03-18-2023, 12:49 PM
                                LCD LED TV Service Menu Codes
                                ALL LCD LED TV SERVICE MENU CODES
                                Service Menu Code with Board Name
                                China Universal Board / Jumper Board Service Menu Code
                                Changhong Ruba Service Menu Code
                                Ecostar LED TV Service Menu Code
                                Orient LED TV Service Menu Code
                                Haier LED TV Service Menu Code
                                TCL LED TV Service Menu Code
                                Samsung LED TV Service Menu Code
                                LG LED TV Service Menu Code
                                Videocon LED TV Service Menu Code
                                Supra LED TV Service Menu Code
                                Toshiba LED TV Service Menu Code
                                Symphony LED TV Service Menu Code
                                Veste/ LED TV Service Menu Code...
                                10-31-2024, 03:58 AM
                                09-06-2024, 11:40 PM
                                09-06-2024, 08:40 PM
                                09-06-2024, 06:20 PM
