Samsung PS42A456P2DXXU **help**
  • karlpowell
    badcaps.net
    • Feb 2013
    • 104
    Re: Samsung PS42A456P2DXXU **help**
    I dont hear any click of the relays
    • Hamie
      • Apr 2014
      • 1383
      Do you get VA with the jumpers in place?
      • karlpowell
        badcaps.net
        • Feb 2013
        • 104
        Nothing on VA from this point with the jumpers in place
        • karlpowell
          badcaps.net
          • Feb 2013
          • 104
          Am i messuring VA from the right place ???
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Ok tell you what remove the jumpers and plug the Mainboard back in, check if you get 3.3v on the Vs on pin if not then the Mainboard isnt sending the signal these Psu's need 3.3v to turn Vs on.
            • karlpowell
              badcaps.net
              • Feb 2013
              • 104
              #26
              with the main board pluged back in and the jumpers removed , stoll 0 Volts on VS-on
              • karlpowell
                badcaps.net
                • Feb 2013
                • 104
                #27
                dont forget the fuse was plown on the power supply when i firts opened this set .
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  #28
                  What I asked so im guessing its blown again ??
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    #29
                    Have you checked the transistors mounted on the heatsinks ?
                    • Hamie
                      • Apr 2014
                      • 1383
                      I know this might see like a daft question but you are actually pressing the "on button" on the TV.
                      I only ask because of you are, and you still have 0v on the vs-on pin, you appear to have both a faulty psu and a faulty main av board.
                      It's strange, although not impossible, to have both boards faulty.
                      What does the ps-on pin read as soon as you press the "on button"?
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        #31
                        That is possible Hammie. I have had on a Ps50c450 psu shorted and killed mainboard shown similar symptoms as this.
                        • karlpowell
                          badcaps.net
                          • Feb 2013
                          • 104
                          #32
                          no , I have no way of testing them but i can replace them
                          • karlpowell
                            badcaps.net
                            • Feb 2013
                            • 104
                            #33
                            it reads 0v all the time BUT there was a piece of paper selotoped over the ON button when i picked it up
                            • karlpowell
                              badcaps.net
                              • Feb 2013
                              • 104
                              #34
                              no all fuses are still OK
                              • Hamie
                                • Apr 2014
                                • 1383
                                Ok so what's the voltages across the main primary capacitor.
                                It should be roughly 340v
                                Then put back in the jumpers, it should now rise to around 380v
                                If it doesn't then you have a problem in the hot side of the psb.
                                • karlpowell
                                  badcaps.net
                                  • Feb 2013
                                  • 104
                                  #36
                                  the 2 main caps on the hot side ?
                                  • Hamie
                                    • Apr 2014
                                    • 1383
                                    Yes measure across the legs of either of them.
                                    Black probe on negative leg of capacitor, red on positive.
                                    Then report back with your voltage.
                                    reapply the jumpers. And check again, report the voltage.
                                      09-07-2024, 05:50 AM
                                      09-06-2024, 11:40 PM
                                      09-06-2024, 08:40 PM
                                      Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                                      This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                      09-06-2024, 06:20 PM
