Samsung PS42A456P2DXXU **help**
  • karlpowell
    badcaps.net
    • Feb 2013
    • 104
    • uk
    Hi, I picked up this set dead a few days ago, on first inspection the PSU had a blown Fuse which I replaced, Now I get 5 red flashes from the set, then the red led goes out.
    Checking the PSU I have p+5v sndby and +3v on PSon and 0v on VS and VA no matter which board is plugged in or unplugged.
    So im guessing this is a PSU fault so started to dig about to replace it but I can only find 1 @ £90 (PSU = BN44-00204A) , so after looking up for a service kit and finding a site selling them for around £28 so i got the service manual and found each part number to see if i could get the parts localy and cheaper .
    QS801 = FQA13N50CF 13n50 3 pin
    QS802 = FQA13N50CF
    DS804 = 1SS355
    DS803 = 1SS355
    RS814 = 10R(2012)F (Not sure what these are im guessing resistors)
    RS812 = 10R(2012)F
    ICS801 = MC33067p
    any help would be great .
    karl
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Samsung PS42A456P2DXXU **help**
    Checked fuses ? Also what about Vs on signal ?
    • karlpowell
      badcaps.net
      • Feb 2013
      • 104
      • uk
      all fuses are good, Vs is always 0
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Hmm ok what about vs on signal ?
        • karlpowell
          badcaps.net
          • Feb 2013
          • 104
          • uk
          Zero volts on both no matter what I do , i have been messuring from these points ...
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            No look on the connectors that go to the mainboard and Tcon there is a pin that should say Vs on that turns on the Vs and Va supplies on the psu do you see it ?
            • karlpowell
              badcaps.net
              • Feb 2013
              • 104
              • uk
              OK .. im guesing second pin in is Vs-ON ? which is 0 votls ..PS = 3v
              • Hamie
                • Apr 2014
                • 1383
                Connect ps-on to ground.
                And vs-on to 5vstby
                • Hamie
                  • Apr 2014
                  • 1383
                  Once done check and see if vs is present.
                  • Hamie
                    • Apr 2014
                    • 1383
                    Sorry forgot to mention do the above with the main board disconnected.
                    • karlpowell
                      badcaps.net
                      • Feb 2013
                      • 104
                      • uk
                      ok ... gimme 5 , your not the same hami from datacave are you ?
                      • karlpowell
                        badcaps.net
                        • Feb 2013
                        • 104
                        • uk
                        just to clear things up are you saying conect and mesure VS from the end 2 pins like this with PS-ON conected to earth via 1 the screw to the chassi
                        • Hamie
                          • Apr 2014
                          • 1383
                          Not me, an imposter! :-D
                          • Hamie
                            • Apr 2014
                            • 1383
                            Can you show me how you connected them?
                            • karlpowell
                              badcaps.net
                              • Feb 2013
                              • 104
                              • uk
                              Like this but using my + probe from meter to connect 5STD and VS-ON
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                Yeah thats good or just solder a small wire bridge.
                                • karlpowell
                                  badcaps.net
                                  • Feb 2013
                                  • 104
                                  • uk
                                  • karlpowell
                                    badcaps.net
                                    • Feb 2013
                                    • 104
                                    • uk
                                    I get 5v
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      Yeah probably best to do it on the underside of the board (less chance of shorting something out) but that will work apply power and see if Vs comes up.
                                      • karlpowell
                                        badcaps.net
                                        • Feb 2013
                                        • 104
                                        • uk
                                        with all this in place i get 0 volts here [/QUOTE]
                                        and + 5volt on the vs on
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
