Dafault Service Menu settings for Samsung (UE40D5000)
  • iffy
    • Sep 2015
    • 6
    • Denmark
    I wanted to have Netflix on my Samsung TV (UE40D5000) but ended up with the mess in the Service menu so TV was not able to boot , i did a EEPROM Reset by opening the back panel, Anyone can help me with the Pictures of the factory data settings in the Service menu so that i can manaully put all values back.
    Thanks in Advance
  • iffy
    • Sep 2015
    • 6
    • Denmark
    Re: Dafault Service Menu settings for Samsung (UE40D5000)
    Hi Guys,
    Please help with my request , To go to to the service menu just Power off the TV using Remote and then press info+menu+mute+power and you will be able to see the Service menu take the screen shots and send me .
    Thanks in Advance
    • iffy
      • Sep 2015
      • 6
      • Denmark
      Hi ,
      Still no reply from anyone .
      Please help to fix my TV .
      • iffy
        • Sep 2015
        • 6
        • Denmark
        Hi ,
        Actual model is UE40D5005PWXXE
        • jasonr2000
          Advance Tech
          • Nov 2013
          • 209
          There isn't likely a way to set this back as most won't have the values but u could always source a replacement main board that will solve all the issues
          Samsung UE46D6530
          Samsung BD-F7500
          Samsung HT-ES6200
            LCD LED TV Service Menu Codes
            TCL LED TV Service Menu Code
            LG LED TV Service Menu Code
            10-31-2024, 03:58 AM
          • Daniel Valdez
            Samsung UN70RU7100K halfway bricked after messing with service menu
            by Daniel Valdez
            Dear All,
            FAFO is the correct definition of what happened with my Samsung UN70RU7100K TV, I was trying to change the region to enable samsung plus using the service mode, entered the mode mute 1 8 2 pwr, and started to dig in. Did some changes while having digital TV signal in the back instead of doing it in HDMI standby mode, I remember changing to a region different then mine but also had a different tuner $%&!. After rebooting the TV, it was all gone, now it shows the splash image and then no image at all. If i disconnect the lan cable from the back, a message is shown in the...
            12-06-2024, 06:56 PM
          • Robby-Gr
            TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
            by Robby-Gr
            I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
            However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
            The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
            Additional issues:...
            09-27-2025, 12:02 AM
          • GeckoGreen
            Samsung service bulletin: need firmware file for PN63C550 TV
            by GeckoGreen
            I'm hoping someone with access to the Samsung GSPN can help me. I need someone with access to download a firmware file for my PN63C550 TV, as it will fix a problem per the Samsung service bulletin.
            You can reference Samsung bulletin #:ASC20130528001 and I need the [2D63]LOGIC.bin file please.
            The full service bulletin is linked here: https://www.avsforum.com/attachments...3-pdf.1080602/
            Will you please help me get the [2D63]LOGIC.bin file for my TV?
            05-17-2025, 02:47 PM
          • tusiime
            How to access Vizio m652i-b2 service menu
            by tusiime
            The current main board on my Vizio m652i-b2 only has 1 of 4 HDMI ports working. Also, the coaxial port is not working.
            So I ordered a replacement board. It boots up the tv, but the display is dark in areas, colors are off, etc. I have seen information online that a setting in the service menu may need to be adjusted. Have tried many ways to access the service menu using remote codes, but none work.
            Can someone here provide the confirmed method for accessing the service menu on this tv? Thanks in advance!
            09-15-2023, 09:57 AM
