LG 55LX6500-UB Where's the EEPROM??
  • kevinm34232
    • May 2012
    • 1884
    I ordered a new EEPROM for an LG 55LX6500-UB in hopes it will fix it.
    Main Board part #: EBR69488901
    EEPROM part #: EAN61133501
    I'm not sure which is the EEPROM IC I need to replace. I though it was supposed to be IC601, but I only found an IC602. I found the below info online, but there seem to be an EEPROM for the LVDS IC, one for the Micro, and some Flash and NVRAM chips. Which one is it??
    https://cdn.badcaps-static.com/pdfs/...c33eabeec0.pdf
  • kevinm34232
    • May 2012
    • 1884
    Re: LG 55LX6500-UB Where's the EEPROM??
    Can anyone help me out with this one?
    • ALittlebit
      • Feb 2015
      • 51
      • United states
      Kevinm what are the symptoms of your tv?
      • ALittlebit
        • Feb 2015
        • 51
        • United states
        On my lg 55LX6500-UB it starts up then the LED back lights go dead but there is no sound and no picture with a flashlight test however the controller and control panel are fully functional.
        • SidneyCanadas
          93C46 and 93C56 EEPROM
          by SidneyCanadas
          I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
          https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
          Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
          06-14-2023, 01:16 PM
        • dmccul2698
          Pioneer DEX-P99rs "No EEProm " diagnostic code.
          by dmccul2698
          Hello, My head unit developed strange behaviors so I ran the built-in diagnostic package which returned "No EEProm". The service manual says there is no EEProm connected. I approached Pioneer and they said to swap out the DSP board. All said and good but the DSP board is $860 USD. I am hoping someone can help me
          1). Understand the schematic and check the connections between the EEProm and DSP
          2). Check the functionality of the EEProm
          I don't know if this is the unit's problem but it's a place to start.
          I have little to no electronic experience...
          04-08-2024, 05:32 PM
        • edgarmg15
          Damaged EEPROM on TV Vizio E320-A0
          by edgarmg15
          Hi everyone
          I´m trying to repair a TV Vizio E320-A0 that I found in the street
          The symptoms are it doesn't respond with remote or buttons, the LED indicator is always off and also there is no image on the TV.
          The power supply board works fine (I probed the terminals with my multimeter) but in the main board the EEPROM doesn't works correctly because the voltage on the pins doesn't match with the parameters of the datasheet.
          So, I´m going to replace the EEPROM with a new one, but the problem is that my programmer (CH341a)...
          11-19-2022, 03:46 PM
        • acedogblast
          by acedogblast
          11-02-2024, 05:13 PM
        • Eotis
          Framework 13 laptop ,Nvram locked ,TPM issue
          by Eotis
          Hi folks. I have a Framework 13 laptop with these specs.
          Motherboard: Framework FRANBMCPOC AC
          Processor: 11th Gen Intel® Core™ i7-1185G7 @ 3.00GHz 3.00 GHz
          Graphics: Intel Iris xe
          Installed RAM: 64.0 GB (63.8 GB usable)
          System type: 64-bit operating system, x64-based processor
          Bios: Uefi InsydeH20 3.24
          Edition: Windows 11 Pro/ AtlasOS
          Version: 23H2
          Installed: ‎9/‎16/‎2024
          OS build: 22631.4169
          Intel Chipset driver: 10.1.19502.8391
          This processor seems to...
          11-18-2025, 08:55 PM
