Samsung LE37r88bd
  • LEEDASH
    • Dec 2012
    • 481
    • Bedfordshire
    Samsung LE37r88bd
    Hi all,I have a problem,with this LCD,I changed some blown caps,which went well,but I'm faced with another problem a blue no responsive screen,the remote doesn't seem to do anything (bn00603a) and on switch on,comes up with p6 mono,the batteries have been changed,any help please,
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Samsung LE37r88bd
    Failed epprom probably usual fault on this model failed caps corrupt the epprom. Try turning the tv off then press info, menu, mute then power and see if the service menu comes up. If so reset the tv.
    • LEEDASH
      • Dec 2012
      • 481
      • Bedfordshire
      Hi how do I reset the TV ? I have just changed some caps which was blown could that have caused problems
      • LEEDASH
        • Dec 2012
        • 481
        • Bedfordshire
        Sequence don't do anything
        • comptek
          • Aug 2013
          • 606
          • uk
          1) find epprom on bottom of main board (ic1803)
          2) take 2 lengths of wire and solder one end of each of the pins 5+6
          3) strip the other ends and make sure they are long enough to pass outside the board when main board is re-fitted...
          4) plug all connections back in
          5) hold the 2 bare ends together so when you let go they will full apart " make sure they dont short anywhere when they separate..
          6) whilst holding bare ends together plug in mains supply count to 2 secs and release leads
          7) press info/menu/mute/power if tv doesnt come on normally
          you may have to repeat the process several times dont give up!
          worse case you will need to by a new chip £2 off ebay i think
          • LEEDASH
            • Dec 2012
            • 481
            • Bedfordshire
            Hi,I have read about this,is it safe ? Do you have to solder the wire,is soldering the only way will it blow anything caps etc ? Like a second view
            • LEEDASH
              • Dec 2012
              • 481
              • Bedfordshire
              So when you solder the wire to pin 5/6 is it a permanent fix or do you have to desolder the wires.
              • Agent24
                I see dead caps
                • Oct 2007
                • 5035
                • New Zealand
                You would remove the wires afterwards, if the fix worked.
                As far as I know, the idea is that you interrupt communication to the NVRAM\Settings EEPROM so when the TV starts it thinks the EEPROM is not there, and starts up with default settings. When you shutdown and restart normally after that, it writes those default settings to the EEPROM, thus overwriting any corrupt data, and allowing the TV to start normally.
                -David VanHorn
                • vinceroger69
                  • Mar 2012
                  • 6714
                  • uk
                  This may help but try at your own risk as i havnt tried this myself
                  http://wiki.samygo.tv/index.php5/UnB...y_EEPROM_Reset
                    09-07-2024, 05:50 AM
                    09-06-2024, 11:40 PM
                    09-06-2024, 08:40 PM
                    Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                    This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                    09-06-2024, 06:20 PM
