Hello everyone,this is my first post and questions i have on the forum so please bear with me if i make any mistakes..
I have read all the stickies and searched in threads pertaining to my model but could not find any info on the problem I am having.
The pics i have attached are of all the boards and if they are not clear enough i will attempt to get closer better ones.
I first thought i had a psu issue & replaced the c802 cap as i had read in other threads,but that didn't solve the problem.
I tested the voltages to video board and the bottom pin read 16.96 volts,the other 2 test pins read 5.2 volts all within the spec on the board.
Then i tested Va & Vs voltages they read nothing zero.
So i then unplugged power source waited 5-10 minutes unplugged connector to video board the powered tv on & the screen flashed on for 1-2 seconds & i could hear x & y boards humming.
So then i tested the Va voltage & it read 55v then tested Vs and it read 204 volts.
Just to note that with the video board connector plugged in to psu the red led on video board is on as well as the red led on the front of the tv power panel.
So is it possible that the video board is bad and causing the problem?
Any help or direction would greatly be appreciated.
