Tevion 32081D Repair
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Ok, fixed two of these TV's so far and there is a lot of work involved in repairing them. Total parts cost for both that I have done is £16 in capacitors from RS and about 2 hours of work.
    Firstly looking at the psu I noticed that almost every cap on the output was blown (capxon and Decon). I fully recapped the psu with rubycon, ichicon, chemicon and Panasonic I also replaced every smaller cap on the psu as they were also starting to go very bad. There are several caps hidden under the heatsinks that you MUST replace on the psu.
    When ever I get a tv with bad caps on the psu I always check the caps on the mainboard..... Glad I did on these !
    Over 35 caps on the mainboard were exploded, they were all this crappy decon brand. Every 220uf and 100uf 16v caps were exploded and blown out the bottom as well as the lager ones with vents. Over half of the caps that I replaced were completely open no esr or capacitance at all, just zapped. You need good soldering equipment and experience to be able to work on a set up like this. You must replace every blown cap as it can cause further issues. Overall junk tv that needs a lot of work but at least they are working pieces of junk. Here is a link to a video on the first one of these I repaired:
    https://www.youtube.com/watch?v=WojR...ykmq1vfvqnvk0k
  • cmlewis89
    LG 47LB5DF blown power supply board
    by cmlewis89
    Hi folks,
    I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
    09-03-2024, 07:50 PM
  • drscoot
    HP X360 convertible battery blown fuse error, not charging
    by drscoot
    HP Modelnumber: 14-dh0061nb​
    This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
    The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
    I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
    And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
    All these 3 batteries are charging...
    12-15-2023, 05:54 AM
  • w00pz
    Identify blown component on HP ENVY X360 13-arxxxxx, Motherboard G1 13 AMD X360 18740-1 448.0GA03.0011
    by w00pz
    I have blown a component on HP Envy x360 with motherboard G1 13 AMD X360 18740-1 448.0GA03.0011.
    Unfortunately there are no schematics available and the component was so blown the marking weren't readable.
    I have marked it with a red circle in the attached photos - sorry for the mediocre quality I was too much in a rush.
    Hope someone will be able to identify the component.
    Many thanks for your help!
    Edit: High-res picture added on a normal board (not mine)...
    11-08-2025, 02:48 PM
  • swerg
    Part selection for possible blown inductor on ASUS GX531-GW-AB76 laptop mobo
    by swerg
    Hey everyone,
    I'm a novice trying to repair my laptop. The LCD screen has an image, but no LED backlight for the image. It also produces an image when connected to an external monitor.
    I have found what I believe to be a blown inductor labeled "L4502" and "120 Ohm" in the schematics (zoomed in image, blue arrow to blown component). I have included an image of the general area of the mobo and an excerpt from the schematics as well.
    I am having trouble selecting a replacement component, which I believe to be a 120 Ohm ferrite bead, from the components...
    06-06-2024, 03:39 PM
  • ohren
    What problems could this blown cap cause in a Marantz SR5400?
    by ohren
    I'm looking at a vented C513 in a Marantz SR5400 (photo included), in the FR section on page 24 in the service manual (https://audiocircuit.dk/downloads/ma...400-avr-sm.pdf).
    R533 right below it in the photo is charred, but measures the correct value.
    1. I'm not familiar with amplifier circuits (at all — don't know the difference between classes, etc.) so I was wondering what problems would manifest from a supposedly non-operational C513? I didn't hear anything odd when testing the output channel with a speaker. Is there a simple test that can be done...
    10-21-2025, 09:02 AM
