Panasonic Plasma TC-P46ST30 Does the power supply stay up with SC board disconnected
  • jcamerox
    • May 2015
    • 34
    I know I have a problem with the SC board, 4 transistors and 2 diodes are bad causing a short to show on the Vsus connector. The SC board is the only one showing a short on the Vsus supply, so with that disconected from the power supply, shouldn't the power supply stay up?
    With the SC board disconnected, and I apply AC, a relay clicks and then when I push the power button the power supply starts up, LED is solid red, Vsus rises to 215 v and then a relay clicks within about 2 seconds, Vsus starts to drop and the LED starts blinking 8 times.
    Is this normal for the power supply? I don't want to fix the SC board and then find the PS is also bad.
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic Plasma TC-P46ST30 Does the power supply stay up with SC board disconnec
    that is normal, make sure you check the sd/su for shorts as well prior to running it after sc repair
    • jcamerox
      • May 2015
      • 34
      Thanks very much for the reply tw2005. I'll double check the sc/su boards and then go ahead with the repair.
      • jcamerox
        • May 2015
        • 34
        I bought a repair kit from "ShopJimmy", TNPA5351 SC board repair kit as it contained the 2 diodes and 4 Transistors that I needed. The board was assembled with lead free solder so needed a lot of heat to desolder the components, they all looked like power transistors. I only used a 35 w Weller soldering iron with a chisel tip but I used lead/tin solder to re-attach the components so it didn't need as much heat. The kit also came with 4 resistors and screws with lock washers to attach the board. The resistors on the board were okay so I left them. A theory is that the attaching screws work loose over time and that causes an intermittent ground which blows the components. The board was torqued down securely with the lock washer screws. I had checked the SD and SU boards for shorts and seeing none I fired it up and SUCCESS.
        It has been running for about 8 hours now and seems fine. I'll let it run for another couple of days before I replace my 42" Panasonic plasma with it.
        • tw2005
          • Oct 2011
          • 6458
          nice, not bad for self repair, they don't always end up easy but it's nice when they do. I hope the solder flowed under those smd transistors. 35watts seems a little light but if it worked, it worked.
            by sam_sam_sam
            03-31-2024, 02:12 PM
            by sam_sam_sam
            07-01-2024, 06:34 AM
          • timtrace
            Won't stay powered on - Sharp LC52LE700UN with RDENCA336WJQZ DPS-286AP power supply
            by timtrace
            Greetings - first post. I'm awed that a forum like this exists. It's a dream come true. I'm not even kidding.
            I've got a 13 year-old Sharp LC52LE700UN television that's developed a problem of powering itself off after 30-45 seconds. If I pull the mains cord and reconnect, it will come back on right away without so much as a button push...then turn off after 30-45 seconds.
            Service manual S37X3LC46E77U is attached to this post, as well as a front and a back picture of the RDENCA336WJQZ DPS-286AP power supply taken after completing my work.
            Each time that the...
            05-14-2020, 09:24 PM
          • shamsudeen
            Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
            by shamsudeen
            Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
            I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
            i know that in linear power supply the noise will be very low comparing to SMPS supply....
            07-19-2025, 07:14 AM
