I have a magnavox 27ms343s (cant find chassis # sorry) that just shuts it self off after it "warms" up. If anyone could help me or maybe inform me of the chassis # id appreciate it! Thanks in advance!
magnavox 27ms343s turns off by its self
Tags: None
Re: magnavox 27ms343s turns off by its self
Originally posted by s_miller_420I have a magnavox 27ms343s (cant find chassis # sorry) that just shuts it self off after it "warms" up.
Chassis numbers is usually written on a label near connectors, in the rear side, or in the manual.
If it shuts down after a few minutes, some components may overheate or be already damaged by overheat: if I were you, I'd detach the tv from mains, open it and clean it from dust. I would look for unstable or cold solderings (the main transformer is a source of heat), burnt areas on pcb, broken components and so on. The manual should have some circuit diagrams you can look, but I'm not into schematics. I can't help more, perhaps somone else can.
Beware: capacitors can retain the charge for hours (don't touch them) and the high voltage cable form the main tansformer to the crt should be never removed.
ZandraxHave an happy life.
This specification for the Acer Aspire Acer Aspire Vero Green PC AV15-51 15.6 inch Laptop - (Intel Core i5-1155G7, 8GB, 512GB SSD, Full HD Display, Windows 11, Grey, 30% PCR Chassis) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire Vero Green PC AV15-51 15.6 inch Laptop - (Intel Core i5-1155G7, 8GB, 512GB SSD, Full HD Display, Windows 11, Grey, 30% PCR Chassis) boardview and Acer Aspire Vero Green PC AV15-51 15.6 inch Laptop - (Intel Core i5-1155G7, 8GB, 512GB SSD,...09-07-2024, 03:10 AM
This specification for the Acer Aspire Acer Aspire Vero Green PC AV15-51 15.6 inch Laptop - (Intel Core i7-1195G7, 16GB, 1TB SSD, Full HD Display, Windows 11, Grey, 30% PCR Chassis) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire Vero Green PC AV15-51 15.6 inch Laptop - (Intel Core i7-1195G7, 16GB, 1TB SSD, Full HD Display, Windows 11, Grey, 30% PCR Chassis) boardview and Acer Aspire Vero Green PC AV15-51 15.6 inch Laptop - (Intel Core i7-1195G7, 16GB, 1TB SSD, Full...09-07-2024, 03:10 AM
by StephenMacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
by mnciks11Hello guys, i need your help fellow brothers
Im diagnosing a Lenovo G80-50 laptop
ACLU3/ACLU4
Rev : 1.0
when you press the power button, the LED power light turns On and quickly shuts down, no display, fan spins a sec and stop. I haven’t seen any short so far.
PU908 (CPU POWER CORE CHIP) is getting hot the moment you press the power button, the laptop turns off very fast, i changed PU908, still im getting same problem, on output side of the 2 cpu power supply coil i get 1.6v and then goes away as soon as the laptop turns off, still the... -
by ZixuTechSeems like we are dealing with a case of a corrupted BIOS after Intel Driver software attempted to flash the bios (haven't seen that before). The customer reported seeing a BIOS message while the screen was flickering during the Intel Display Driver installation. This was while the BIOS WRITE lock jumper was in place. Resulting in Loop restarting.
Afterwards, the customer attempted flashing BIOS via USB stick, resulting now in turning and immediately shutting down unit NUC8I7HNK4.
Under the thermal cam, I can see that the CPU is initiating a heat signature for a second...-
- Loading...
