HTS3306 Blueray shutdown after 15 secs.
  • crdz66
    • Nov 2012
    • 242
    Hi Friends.
    I have a problem with a Blue Ray Home Theater than shutdown after 15secs.
    As soon you turn on the system show a message there is a short on speaker cable.
    I not have a clue how start check this.
    Not components damage at first view.
    Any Idea
  • cruiser_
    A1466 820-00165 intermittent shutdown
    by cruiser_
    hi there,
    Got this macbook after liquid damage. Nothing major, cleaned and reflowed what was suspect. Now, the laptop turns on and boots up but shuts off intermittently - sometimes after a few minutes, sometimes after a few hours.
    Can be immediately started from keyboard right after. Plug stays orange during this time. No battery.
    Gives shutdown cause -128.
    Seem to work fine in SMC bypass.
    Same shutdown happens with disconnected TP/KB/KBLED/CAM.
    Observations:
    - SMC_RESET_L - when pulled down - plug goes orange/green and...
    10-11-2022, 12:06 PM
  • RATIM SIDDIQUE
    hp fpw50-la-h323p rev 1.0 automatic shutdown after 30 sec, need help
    by RATIM SIDDIQUE
    automatic shutdown after 30 sec of display coming
    do not shutdown without ramstick
    someone give me idea plz
    08-20-2024, 03:50 AM
  • howardc64
    P502UI-B1E shutdown automatically after 75s followed by power light blinking 15x
    by howardc64
    History
    - Got TV free. Prior owner claims Vizio logo shows up then nothing. He found U202 EEPROM replacement info (I know NickTV says its never EEPROM haha). Lifted 5 pads removing U202 without proper tools and thought thats end of main board. Gave the TV to me.
    - I repaired U202 pads and connections. Soldered on prior owner purchased aftermarket EEPROM (original EEPROM was tossed). TV boots to VIZIO logo, then goes blank, shutsdown after a min or so and power on light blinks a number of times.
    - Fixed 2 circa 2015 Vizios before with classical main board...
    11-28-2020, 04:25 PM
  • ronelex
    Acer MS2304 Shutdown when HDD or ODD Present
    by ronelex
    Model: Acer MS2304
    Board Code: 09920-2
    Issue: Unit Powers On with Display Without HDD or ODD attached
    When ODD or HDD is present unit powers on then Shutdown it reaches current of 1A that looks like want to boot but it will shutdown
    Unit wont shutdown when ODD or hdd attach if no ram is attach also
    I have tried flashing bios, the only different it will not shutdown immediately reaching 1A but eventually will shutdown also
    05-15-2021, 01:28 AM
  • IamPritesh
    Help - Auto starts after 1 minute of shutdown - Dell vegas/turis 15341-1
    by IamPritesh
    I have two such machines which is having this issue. After shutdown the system starts on its own in a minute. It does not start immediately. It takes around 20-40 seconds before it starts again on its own. This is driving me crazy and not sure where to start ..
    Some very important points :
    • Laptop does not auto starts after shutdown if adapter is connected.
    • It will only auto start after shutdown if the laptop is in BATTERY only mode.
    • I have tried replacing batteries with a known
    • if I shutdown the laptop with adapter connected and lets say remove the adapter after 5-10
    09-24-2021, 05:01 AM
