LG 55LD520 - No Backlights, No Image, No Sound (Lot's of Pictures!)
  • TheAssassin
    • Jul 2015
    • 10
    Good evening (or morning) everyone,
    I have an LG 55LD520 that I purchased two years ago and is out of warranty. A few days ago, lightning struck very close to my house. Despite being hooked up to a surge protector, the TV no longer works.
    When I turn on the TV, the red LED indicator at the bottom flashes a few times and then goes to solid blue. However, the backlight does not turn on and there is no image (obviously). The flashlight trick yields nothing. Given that I cannot determine which input I am on, I cannot verify if I have sound.
    I am fairly technologically inclined (built computers, engines, and the like) so I opened up the back panel and started probing with a DVM.
    With the TV on, here is what I found:
    AC Plug to PSB (EL1) (brown wire): 1.3V - 3V continuous fluctuation.
    AC Plug to PSB (EL2) (blue wire): 1.3V - 3V continuous fluctuation.
    C613 +: 320V (This was measured by using the positive lead and a common ground. I didn't see the suggestion on this site to measure the voltage by using both capacitor leads until later.)
    The following results are with the inverter boards unplugged and plugged in (no differences):
    P201: all voltages/grounds matched the printed value. I wasn't sure what value was normal for the non-numerical, non-ground labels.
    P202/P203: all voltages/grounds checked out.
    So my question is this: what else am I to look for? Any fuses on the inverter boards? I saw two fuses on the power supply board (both showed continuity), are there anymore?
    I'm attaching a few pictures of the power supply board and components. There is a suspect area on one of the heat sinks with the black things screwed to them (not sure what they're called). I can't tell if it is heat damage or just assembly dirt.
    (I tried uploading the pictures via this site's attachment function but couldn't get past the "Uploading Files - Please Wait" message. So I'm using Photobucket instead.)
    P201
    P201
  • TheAssassin
    • Jul 2015
    • 10
    Re: LG 55LD520 - No Backlights, No Image, No Sound (Lot's of Pictures!)
    Here is the potential heat damage I was talking about:
      How about the Voltage readings of the signal pins, for example PWR, INV-ON, A-DIM, etc, we need to know ALL the voltages of all those pins to see if the main board is sending those signals to the power supply board or not.
      The wires are in the way so we cannot see all the pin names.
      • TheAssassin
        • Jul 2015
        • 10
        Thank you for the quick reply.
        All the pin names are visible. The last two pictures in the first post are the same socket, just different sides. The other ones don't have any labels on the side that's blocked by the wires. Sorry if that wasn't clear. I labeled the last two pictures as P201 just now.
        I will get readings for these now.
        • TheAssassin
          • Jul 2015
          • 10
          Ok here are the readings with everything plugged in and the tv on with solid blue LED indicator light:
          P201 (goes from the main board, with all the in/outputs, to the power supply board):
          ERR: 0.0V
          P-DIM #1: 0.1V
          A-DIM: 2.4V
          INV-ON: 0.0V
          PWR: 24.3V
          P202 (goes from the power supply board to the inverter board on the right (left if looking at the tv from the front)) :
          INV-ON: 0.0V
          ADIM: 2.9V
          P204 (goes from the power supply to the inverter board on the left (right if looking at the tv from the front)) :
          ERR: 0.0V
          PDIM #1: 0.1V
          INV-ON 0.0V
          ADIM: 2.7V
          Let me know if you need more readings.
            "INV-ON: 0.0V" You are not getting the BL-ON signal to turn on the backlights, The inverter is getting the needed 24V and the A-DIM (Analog Dimming signal to control the backlights brightness) signal. So something is causing the main board not to send the signal to to turn on the backlights. The PS-ON (PWR)is working otherwise you will not have the 24V.
            Try disconnecting the cables between the T-CON board on the panel and the main board to see what happen. You should also try to see if any of the IC on the main board is getting too hot to touch.
            • TheAssassin
              • Jul 2015
              • 10
              I disconnected the T CON board and measured the INV ON voltage again and still get 0.0V.
              I couldn't discern any noticebly hot IC's on the main board.
              What would cause the main board to not send the signal to turn on the inverters? Or is it not that simple to diagnose yet?
                The processor, the other failed circuits that cause the processor to hang up, bad caps, bad resistors,, bad connections, bad BL-ON switched transistors that is not toggling when it gets the command from the processor. It will be time consuming without the diagram to do component level troubleshooting.
                • TheAssassin
                  • Jul 2015
                  • 10
                  Thank you for your response.
                  While I am comfortable checking for voltages and such, I don't think I'm quite on the level of replacing individual parts like capacitors, resistors, transistors, etc. I'd rather purchase a new main board than try my luck at resoldering components. (I was never very good at soldering.)
                  The way I see it, there are several boards that I'd be ok replacing. The power supply board, the main board, the four inverter boards, and the T-CON board. If you think, with the information I've provided, that the faulty board is the main board, then I would go ahead an purchase a new main board.
                  • TheAssassin
                    • Jul 2015
                    • 10
                    I found the main board on shopjimmy.com. Do you think this issue is caused by a faulty main board?
                      The main board is not sending the command signal, so that will be the starting place.
                      You should also contact shopjimmy to see what they think.
                      • TheAssassin
                        • Jul 2015
                        • 10
                        Shop jimmy's site states that they are not answering TV technical questions at this time.
                        I am going to purchase a new mainboard and see if that works. I'll keep you posted.
                        • TheAssassin
                          • Jul 2015
                          • 10
                          A new main board from shopjimmy.com solved the problem! Thank you budm!
                          • Rhyno_78
                            • Nov 2016
                            Hello everyone. I am new to the site and looking for help in troubleshooting the same LG Model. I have narrowed what I think is possibly the main board but wanted to seek everyone's thoughts here first.
                            On the power supply board, connector "P201", I have separated the "ERR" & "INV-ON" wires from the connector. By doing this, I get backlights on the tv, but no logo display. If I connect the "ERR" wire to the connector, I get a strobe effect on the screen. If I connect the "INV-ON" wire to the connector, the screen goes completely dark with no back light.
                            Can anyone help me identify where to go from here ?
                            • bohaboha
                              Samsung UE70TU6905 BACKLIGHTS AND SOUND ON NO PICTURES BUT SCREEN NOT DARK
                              by bohaboha
                              Hi it looks like everything works don't know where to test except the 390v in the 2 capacitor in the hot side of the power supply and the weird 180v in the diodes in the cold side that should be discharged it is writin on the circuit no more you can read what is written on the circuit quite srrange color mixiing yellow and white
                              anyhow i couldn't t read anything else
                              the backlight is on strong and the screen does not get dark or very dark but no pictures
                              the mainborad feels a bit hott on the black part i test it to 52 degree's against 34 to 40 on the rest of it
                              01-02-2025, 08:04 PM
                            • max789
                              Samsung UE48H6410 replaced Mainboard but backlights doesnt go on
                              by max789
                              Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
                              I made the following tests:
                              1. Disconnected the main board from Power Board = backlight works.
                              2. Connected the main board and disconnected the T-Con = backlights does not work.
                              So I ordered a main board from Ebay also BN41-02156A but from...
                              01-18-2024, 06:56 AM
                            • bpcannan
                              VIZIO M557-G0: Backlights or ???
                              by bpcannan
                              'Morning,
                              I get sound and picture when powering on the TV and its stays that EXCEPT that the left half of the screen will dim every few seconds then return to normal while the right side of the screen performs as designed.
                              Did the soft and hard reset options pulling the plug, using the reet option in the vizio menu to no avail.
                              I checked the mainboard - found some popped capacitors so replaced it - but that did not change the situation.
                              I checked the t-con board. It is getting good power. Then I removed one ribbon cable to see if I could isolate...
                              10-29-2023, 06:36 AM
                            • jesterace
                              Samsung UE49MU6400 acts dead until disconnecting backlights, then works.
                              by jesterace
                              Hi everyone I have this TV which was dead one day when I tried to turn it on. I've had the cover off and there was just a pulsating/electrical clicking/ticking noise from the PSU. I disconnected the mainboard as sometimes this works to just fire it up with backlights on? That didn't help. Same noise. Then I disconnected the backlight cable from the PSU and the TV came alive. It appeared to respond to the remote and i'm pretty sure it's fully operational when there is no backlight connected.
                              However, I am in a dilemma.
                              I tested the backlight outputs with the lights disconnected...
                              10-20-2024, 10:15 AM
                            • lostone
                              Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                              by lostone
                              Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                              First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                              When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                              05-19-2024, 11:40 AM
