samsung t260 hd no power no led power lights
  • feer
    • Jul 2015
    • 10
    • usa
    hi to allguys i got a samsung t260 hd yesterday power on like few second flicker screen black then go off no more, power or led light on power button dissemble the monitor then remove the inverter tm-0918 i know the The secondary resistance is about 940 ohm between S1 and S2 (or S3 and S4). The primary resistance is about 0.3 ohm between P1 and P2.
    mine are secondary resistance is about 1032 ohm between S1 and S2 (or S3 and S4).
    and The primary resistance is about 0.3 ohm between P1 and P2. mines in P1 and P2 are primary resistance is about 0.9 ohm ? any insights on this would be a bad invert er any help greatly appreciated thanks fernando...
  • GLISIT
    by GLISIT
    01-16-2025, 02:29 PM
  • mrtek
    Samsung UN43NU6950FXZA No power
    by mrtek
    Hi
    Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
    Main fuse = OK
    Back light LED = OK. Power them with aux power source
    LED output = OK 156V
    I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
    Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
    07-20-2025, 08:06 PM
  • WVUfan
    PS5 EDM-033 One Beep,No Lights, No Power Troubleshooting Help
    by WVUfan
    hello. i've a ps5 edm-033 mobo w/ no power, lights, but one beep when power pressed. i've hooked to uArt and only error code is 80871001 (DDR4 No Power or Short Circuit). i have a donor board, same model, that does power up, fan spins, blue light, and beeps 3 times, then powers off. it has a botched HDMI port replacement job. so w/ the board i'm interested in, with the error 80871001, i was able to research and obtain voltages of the SSD PMIC. i've attached pictures of the provided diagram by DylanBBK (@d62 on Discord) and my voltages and picture of my board. my question is on my picture...
    08-11-2025, 01:12 PM
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • TKF
    Samsung BN44-00775A no Power No STB or Power lights.Help needed
    by TKF
    After a lot or reading and searching I suspected PB Power Board#BN44-00775A but after voltage tests I'm not sure what they indicate or point to.
    1st I unplugged MB and left only BLs plugged in to see if I got light No BLs come on. So I suspected Black lights but then tested BLs with BL tester they came on. I suspect a short somewhere I started testing at the STB pin 8v/on13v I get 12.80v note no stb lights on
    I noticed with only MB plugged in MB showed signs on life saw red light on not sure from where and it started warming up.
    Thanks for any help or ideas or testing suggestions...
    06-26-2023, 11:05 AM
