pwb dps-336ap
  • knightdad
    • Apr 2015
    • 54
    • usa
    pwb dps-336ap
    with pb out of set an nothing plug in exc power cord
    is there volts to pson ??? all i read was that pson to ground to trun on
    board i get standby volt an volts to pson 5.0 volts to bouth
  • Mcfeetroy
    Fishing bite alarm drains battery
    by Mcfeetroy
    Good day to all. The bite alarm drains 9-volt Krona batteries. Current consumption when switched on is about 50 mA. I wiped the board from oxides, I will attach a photo (on the board there is a j3y transistor and a 7533 stabilizer, the microcircuit is erased = (the 3.3-volt stabilizer heats up weakly. I replaced it, nothing changed. I unsoldered the microcircuit, the consumption disappeared. The resistance on the pins of the unsoldered microcircuit from the point clockwise is more than 2 megaohms, the 11th leg is presumably ground. I warmed up the microcircuit, the consumption does not change....
    08-01-2025, 03:52 AM
  • MisterAIL
    PS5 digital / No Power / No Beep / Good power supply
    by MisterAIL
    Brought a non functionnal PS5. Apparently only a bad PSU...
    No beep, nothing.
    After some tests i found this :
    - PSU is fine (12 volts stable)
    - 12 volts line is shorted
    - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
    - By the way, nothing change. No signal, no power, no beep.
    Mesuring all rails with my workbench psu (12 volts input)
    - 0.00 amp drawing
    - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
    03-12-2024, 03:24 PM
    12 volt switching power supply modification to 14.5 volts before blocking diode add
    I saw this switching power supply on eBay and wanted to see if could be modified to run 14.5 volts before the blocking diode was add and this switching power supply seems to have no issues doing this
    I did recap the switching power supply except the the main filtering capacitors and I managed to break the selector switch for the voltage setting but just jumped it
    One note I used 25 volt capacitors on the output side of this power supply because they used 16 volt capacitors and because I am running the voltage up a little bit higher 12 volts to 14.5 volts there would...
    04-11-2021, 11:01 AM
  • EasyGoing1
    Need a circuit that switches ON when a 5 volt source drops to 4 volts or less
    by EasyGoing1
    I don't know the first thing about where to even start looking for the result I'm looking for ... but what I want, is a circuit ... or maybe a certain transistor ... that will remain "closed" when the voltage at the base is 5 volts, but when that voltage gets to 4 volts or less, I need that transistor to turn on - preferably with maximum saturation. I would prefer that it also does not even turn on a little as the voltage approaches 4 volts, but remains closed until that voltage hits 4 volts.
    Now, it would be OK if it had some kind of marginal transition from zero saturation...
    01-08-2020, 06:06 PM
  • Mark R
    The Overseas Only Kenwood Model KR 790
    by Mark R
    I am Repairing this unit. It had many problems. One major one was the power transformer being about 4-5 volts low on the main B+ line which called for 66.5 Vols after the Main Filter caps but only showing about 62 Volts. Caps and the 5 amp Diode bridge were replaced which helped slightly.
    The other strange problem was the small secondary winding from the PT which supplies 18 Volts AC to the "FM FLUORESCENT DISPLAY" circuit, and the small winding that supplies 8 Volts AC to the push button grain of wheat lamps. Those voltages were down from 18 Volts to 16 volts. Which was...
    09-23-2025, 08:27 PM
