jVC LT-Z26SX5
  • LEEDASH
    • Dec 2012
    • 481
    • Bedfordshire
    jVC LT-Z26SX5
    Firstly hi all,Screen fault on a jVC LT-Z26SX5,around half way down,not running from left to right or top to bottom,i have cant even call it a straight line,a long blob of multi coloured something or other,will post a picture but didnt know if anyone had had model in the past,know its getting on now in years,
    thank you
  • LEEDASH
    • Dec 2012
    • 481
    • Bedfordshire
    Re: jVC LT-Z26SX5
    • flocko
      • Nov 2012
      • 1121
      Re: jVC LT-Z26SX5
      I would say something has laid on the screen (pressure mark) and non repairable
      • Hamie
        • Apr 2014
        • 1383
        Re: jVC LT-Z26SX5
        Bad panel by the looks of it.
        • LEEDASH
          • Dec 2012
          • 481
          • Bedfordshire
          Re: jVC LT-Z26SX5
          Ok thanks for the input,also can get it to select to install the freeview channels
          • Dan20701
            Dell Latitude 5420, Coloured screens from one colour to another continuous.
            by Dan20701
            Hello all, I have a Dell Latitude 5420, before I upload the bios I thought I would ask. All I am getting is are coloured screens from one colure to another continuous that's all its doing.
            I have searched on google some say this is a graphics problem and not a bios problem. I did try another bios file from the forum it stops at the Dell logo.
            With the original chip fitted I am getting error code 3 amber and 3 white flashes.
            Any advice please ?.​
            09-02-2024, 03:43 AM
          • pni
            LG 49uf695v vertical coloured lines
            by pni
            Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
            11-14-2025, 03:15 AM
          • Crystaleyes
            What's inside a Blob?
            by Crystaleyes
            Is something I had often wondered.
            After picking up a DMM with a fried selector circuit trace, I thought I'd have a look and find out.
            And now you know too
            Tell you one thing, it's some seriously tough shit....
            01-20-2023, 12:30 PM
          • redwire
            Multimeter LCD display blob
            by redwire
            Anyone know what this strange blob on the multimeter LCD display is? Ideas to repair it?
            Picked up the Beckman TECH 360 bench multimeter from fleabay in new condition. It's just been sitting in storage.
            I thought a polarizing film or heat, but the G segment looks dead on a digit....
            05-31-2021, 04:39 PM
          • polaro
            Thin stable coloured vertical lines on Samsung UN65NU6900FXZC come and go
            by polaro
            Greetings,
            I've bought a used Samsung UN65NU6900FXZC LED TV. It worked fine for some time and then developed, at first, a single very thin (1 pixel) vertical stable blue line, from top to bottom, close to the left edge of the screen. Now it's 3 lines on the left. When I connect HDMI sources the number of the thin lines grow. After disconnecting and cold discharging I am back to 2 lines. The lines disappear at a rate of 15-20 minutes per line. So it does not look like a damaged LED panel. Any advice? Thanks...
            08-27-2022, 08:46 AM
