Power Supply Fuse Question
  • Saltfrog
    • Jun 2015
    • 20
    Are most or all the fuses found on LCD/Plasma PSU's primarily the ceramic slow blow style? I've seen very few with the glass style fuses and mostly see the white ones. Any suggestions or preference where I should order from? I've always gotten my caps from Mouser and I hate to order just one or two of anything. I usually order caps by 10 or more but didn't want to buy bulk fuses and not be able to use them down the road. Appreciate your thoughts once again!
    Re: Power Supply Fuse Question
    Ceramic body fuse will not shatter like glass body fuse when encounter high interrupting situation, UL probably require them to use when it went through the compliance testing, otherwise they would have used glass body fuse which is cheaper.
    http://www.littelfuse.com/products/f...2mm-fuses.aspx
      Surface Mount Fuses Fundamentals Datasheet
      TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
      TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
      10-07-2024, 06:07 AM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • Babbar
      by Babbar
      04-12-2024, 01:12 AM
      03-31-2024, 02:12 PM
      Used a Ring tester to troubleshoot a switching power supply that has a blowed fuse
      I found this switching power which has a blowed fuse checked diodes which were still good out of circuit checked main filtering capacitor with an ESR meter 220uf@450 volts 0.15 value which to me seem bad but maybe not but without these items not in the circuit because I have about 8 ohm on the output of the capacitors so I removed the switching power supply transformer and checked it with a ring tester and all but one winding showed good all others either showed two red lights or no lights on and one winding had all lights on which was the only one that was good
      One other check that...
      08-03-2021, 06:41 PM
