Sony Bravia 32d3000 dark picture
  • Ice203
    • May 2015
    • 99
    • Uk
    I have the above TV which when first turned on has dark picture.
    Only Colors visable are faint reds.
    But if I press menu that is visable.
    TV then comes on after about ten minutes.
    I did read about bad tabs and flexing the screen might work. But didn't make any difference
    So wondering if it could be anything else.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Sony Bravia 32d3000 dark picture
    Try cleaning the Flat Ribbon cagles to the T-CON board. For extra measure I'd wet a
    Q-Tip with WD-40 and moisten the fingerling tips of the cable then reseat them. Worked for me different TV similar symptom.
    • Ice203
      • May 2015
      • 99
      • Uk
      Thxs. Will try that and let ta know.
      • Ice203
        • May 2015
        • 99
        • Uk
        Done what ta said Andrew. And so far so good. Will c what it's like in morning after few hours unplugged.
        • Saltfrog
          • Jun 2015
          • 20
          Also have Sony Bravia with the tab problem. (46") I pulled the frame off and used the thick foam tape which solved my problem. My faulty tab was the top left side. I did have the problem reoccur but I don't think I used a thick enough piece. Mine only acts up when cold and goes back to normal when it warms up.
          • CyberPhoenix
            Issue with picture quality of Sony bravia TV
            by CyberPhoenix
            Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
            01-22-2024, 02:08 AM
          • Spc.
            Sony Bravia KD43XF7596BAEP - Android no picture
            by Spc.
            Greetings everyone.
            I also have Sony Bravia, model:
            Sony Bravia KD43XF7596BAEP - Android.
            What happend is that image dissapeared while we were watching tv.
            Diagnostics:
            1. TV turns on, no errors
            2. Backlight turs on, no errors
            3. Power indicator turns on, white color, no errors
            4. Menu works on android, you can hear sound while switching channels
            5. Volume up and down works via TV remote and via buttons
            6. Tunner works, HEVC / MPEG-4 decoder works
            7. I get audio from channels
            8. No picture is present,...
            05-19-2022, 04:28 AM
          • KYBOSH
            Trying to Save - SONY BRAVIA KD-75X780F - No Picture BUT there’s sound
            by KYBOSH
            Previous owner said TV just went blank one day.
            They attempted to open the back panel and yanked the power connector off the power supply in the meantime.
            Easily fixed that and got the TV to turn on. Backlights come one with everything connected. Good Sign.
            The mainboard shows signs of life (red light on digital audio out is on) but that's about it. Good Sign.
            There is not blinking LED and the most importantly there is LED response and sound when I press the MENU button on remote control. GREAT Sign.
            I just downloaded the Sony KD-75X7800F Service Manual and...
            11-19-2024, 10:12 AM
          • lmcancu
            Sony Bravia 65x900F BL On but not picture
            by lmcancu
            I was watching youtube yesterday, when I paused it to go to the washroom. When I came back, the right side of the screen was showing half of the youtube channel and the left was black. I powered off/on the unit with the remote and now I have no picture whatsoever except for the bluish backlight. I did the factory reset (power + vol down), and now I when I power on I get the startup music, backlight but no picture.
            I took the back cover off, and reseated all cables but unfortunately same issue. I took some voltage measurements on the main 2 headers from the power supply board and...
            10-30-2023, 07:01 PM
          • JUCaESAl
            Sony bravia KD-65AF9
            by JUCaESAl
            Hola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
            Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television.
            10-20-2025, 04:03 AM
