Re: Samsung LN46A550 Power Cycling
http://www.hbelects.com/index.php?ma...roducts_id=625
I do not see the spec, but if Terryfictv uses it and it works then it should be OK.
So were the ones I ordered from HBElect.com decent for the job?Leave a comment:
https://www.badcaps.net/forum/showpo...&postcount=135
https://www.badcaps.net/forum/showth...t=25810&page=7Last edited by budm; 06-30-2015, 01:24 PM.Leave a comment:
budm, I tried looking up the caps online but couldn't find any information on it - on a legible website haha. I ordered the ones from HBElect that terryfic suggested, will these work? Thanks,
ZackLeave a comment:
So you did not use the low ESR cap to try out if it will make the TV to come on. I have done many experiment with paralleling the caps to see how long it will last compare to the original caps, so far none of them came back yet.Leave a comment:
Ordered from HBElect, Thanks TerryLeave a comment:
Mouser.com 581-TAP476K016SCS $2.16
HB Electronics 12T-215 $1.15 hbelects.comLeave a comment:
What is a low enough ESR for this application? Which capacitor off of digikey or mouser did you guys use?
Thanks,
The old SMD capacitors are not on there anymore... I can replace the Su scon but I don't know what to test from there? Should I just order those SMD capacitors? It seems like something else could be wrong with the board... because I replaced the capacitors with Can capacitors and I heat up the same spot on the board and it works... Could be that those capacitors aren't working correctly though...
Try a brand new, low ESR, good brand capacitor instead of a used and possibly defective Su'scon.Leave a comment:
Cap replacement is most reliable with 47@16v TANTALUM type !
Jumping,paralleling or bridging the bad cap adds capacitance but
still allows the AS7 on the board to cause a problem. So,the best
repair is to replace both.Leave a comment:
PS, I did not screw up the board by removing the tantalum SMD caps. I just took them off with my solder gun, very carefully, and replaced them with 47UF 25V Can shaped capacitors from various boards I have laying around.Leave a comment:
The old SMD capacitors are not on there anymore... I can replace the Su scon but I don't know what to test from there? Should I just order those SMD capacitors? It seems like something else could be wrong with the board... because I replaced the capacitors with Can capacitors and I heat up the same spot on the board and it works... Could be that those capacitors aren't working correctly though...Leave a comment:
Are the old SMD capacitors still on there?
Could be your replacements are not good enough. And I wouldn't use Su'scon, they're horrible....Leave a comment:
Replaced both of them and still no dice... replaced with can 47uf caps... still turns on when I put hair dryer in the area...Leave a comment:
The electrolyte in C131 is probably crystalline and when it is heated it turns liquid again and the capacitor start to work.Leave a comment:
I scraped off some green stuff down to the copper on either side of c102 and soldered it to that hahaLeave a comment:
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by high-techHello everybody, I could use some help on this one... It's got me guessing...
I took pictures of all the boards and the pin out of the connector on the power supply that goes to the main board... I measured all the pins in relation to chassis ground, here are the result.
(B13v)1. 12.7 volts cycling (Vamp) 2. 12.7 volts cycling
(B13v)3. 12.7 volts cycling (PWM5) 4. 1.0 volts cycling
(OD_LE)5. 2.8 volts cycling (PWM4) 6. 0.9 volts cycling
(OD_ON)7. 2.8 volts cycling (PWM3) 8. 0.9 volts cycling
9. ground (PWM2) 10. 0.9 volts cycling... -
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
This specification for the Samsung Galaxy Book Ion NP930XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ boardview and NP930XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 08:40 PM
- Loading...
