Samsung LN46A550 Power Cycling
    Re: Samsung LN46A550 Power Cycling
    That is MLC capacitor, is it bad or something?
    That is just noise bypass on FB Pin 5 of IC MP2363.
    • buckscrape
      • Mar 2016
      • 14
      It is actually next c101
        Yes, I did see in the picture (https://www.badcaps.net/forum/showth...t=47214&page=3) that you have marked and it is the bypass cap.
        So the question remains, is it bad or what?
        So you are not going to replace c102 for the common failure mode?
        • buckscrape
          • Mar 2016
          • 14
          It's is next to C101
          • buckscrape
            • Mar 2016
            • 14
            On my board it is gone, my mistake dropped solder on it when taking the solder off the C139 came off with it, now I need one do not want to get the whole board for a stupid mistake.....how stupid do I feel!
            • buckscrape
              • Mar 2016
              • 14
              On my board this very small MCL? is gone, my mistake dropped solder on it when taking the solder off the C139 came off with it, what size is it, what do i get now I need one do not want to get the whole board for a stupid mistake.....how stupid do I feel![
              • Agent24
                I see dead caps
                • Oct 2007
                • 5037
                • New Zealand
                #67
                Someone else with same board will need to desolder and measure for you, unless you can find the schematic...
                -David VanHorn
                  So is this cap connected to FB Pin 5 of IC MP2363 and GND?
                  • martino
                    Not so "senior"
                    • Aug 2013
                    • 997
                    • canada
                    #69
                    I got that board here,what do you want me to measure?
                    Proud owner of dozens of broken TV's and many,many,many boards.
                    Our website and passion:http://hollenhundshepherds.com/
                      We need to see how the cap C101 is connected to the MP2363 circuit.
                      Is one end of the cap connected to pin 5?
                      It looks like it is also connected in parallel with the resistor next to it.
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 5037
                        • New Zealand
                        #71
                        I thought he wanted to know the value of C139?
                        -David VanHorn
                        • buckscrape
                          • Mar 2016
                          • 14
                          I need to know the value of C139 then pick one up to repair
                          • martino
                            Not so "senior"
                            • Aug 2013
                            • 997
                            • canada
                            #73
                            I'm reading 30pF. That's in circuit,I'm afraid if I desolder it,I will never find it again,lol
                              Sorry my mistake.
                              • buckscrape
                                • Mar 2016
                                • 14
                                Where can I pick up this MLC 30pF......?
                                • buckscrape
                                  • Mar 2016
                                  • 14
                                  Picked it up @ U-Do-It Electronics, Needham, MA.....This place has everything and anything and if they don't they will order it for you!
                                  • buckscrape
                                    • Mar 2016
                                    • 14
                                    Help me PLEASE.....! What are these items.....?
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      • uk
                                      #78
                                      Do you mean what they are as in two resitors and one capacitor or do you need the values the resistor has it wrote on it not sure what value the capacitors are though maybe in the schematic though.
                                      • buckscrape
                                        • Mar 2016
                                        • 14
                                        I need to know the values of all three (3). Where can I get a schematic?
                                        • vinceroger69
                                          • Mar 2012
                                          • 6714
                                          • uk
                                          #80
                                          maybe this one but does depend on what chassis the set uses does it say on the back panel sticker whats wrong with your tv are these parts burnt/missing?
                                          http://www.hobby-hour.com/electronics/smdcalc.php
                                            09-07-2024, 05:50 AM
                                          • high-tech
                                            Samsung UN55F7050AFXZA ver. TD01 power cycling
                                            by high-tech
                                            Hello everybody, I could use some help on this one... It's got me guessing...
                                            I took pictures of all the boards and the pin out of the connector on the power supply that goes to the main board... I measured all the pins in relation to chassis ground, here are the result.
                                            (B13v)1. 12.7 volts cycling (Vamp) 2. 12.7 volts cycling
                                            (B13v)3. 12.7 volts cycling (PWM5) 4. 1.0 volts cycling
                                            (OD_LE)5. 2.8 volts cycling (PWM4) 6. 0.9 volts cycling
                                            (OD_ON)7. 2.8 volts cycling (PWM3) 8. 0.9 volts cycling
                                            9. ground (PWM2) 10. 0.9 volts cycling...
                                            09-15-2020, 03:39 PM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
