Samsung ps42b451
  • adamp91gvm
    • Jan 2014
    • 706
    Samsung ps42b451
    It will not turn on just clicks over and over but when the t con is disconnected it makes the power up sound
  • adamp91gvm
    • Jan 2014
    • 706
    Re: Samsung ps42b451
    When t con is disconnected the vs and va are correct
    • munja
      • Apr 2015
      • 5
      • Serbia
      which have voltages on control board?
      • adamp91gvm
        • Jan 2014
        • 706
        I have tried it with another control board and still the same
        • adamp91gvm
          • Jan 2014
          • 706
          Anyone had the same issue with this tv
          • sordids999
            • May 2013
            • 2161
            not sure if this helps but have you tested the x-main for shorts plus the Y-sus/buffer board ?
            i recently fixed the ps42c450 im wondering if its the same where a faulty x-main can take out the ybuffer and y-main as well
              09-07-2024, 05:50 AM
            • jchang
              Samsung UN70NU6900F no picture and no sound
              by jchang
              Hi all
              I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
              Symptom:
              No picture no sound.
              When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
              No sound at all.
              What I tried:
              1. I tried unplugging the left or right ribbon...
              01-09-2023, 06:28 PM
            • ChaosLegionnaire
              by ChaosLegionnaire
              09-13-2022, 09:02 AM
              09-06-2024, 11:40 PM
