Samsung 40" LCD LA40N81BDX/XSA Main board source
  • Geniee33
    • Jun 2015
    • 45
    I have a Samsung 40" LCD LA40N81BDX/XSA which i repaired the caps on the power supply,
    The TV still wont turn on, so i attempted to reset the EEPROM on the main board.
    Well, lets just say, i made a bit of a mess, and am looking to try and replace the mainboard now.
    I cannot find anywhere that they sell this board.
    The main board is a BN94-01200F
    i have chececked ShopJimmy.com and other Google searches, but there is very little info on this board.
    I was hoping someone here may know of another source to find the board or know of any alternative boards that would also work in its place?
    I ask this because i found one ad where a guy had stripped down the same TV and was selling the main board from it, but it was a different main board code BN94-01578D
    The ad also mentioned that this board would work in a LA40M81
    Is anyone able to help?
  • lus82
    • Jun 2015
    Re: Samsung 40" LCD LA40N81BDX/XSA Main board source
    I had the same TV model and and have come across same issue. I have tried the same thing and made a mess of main board when I tried to replace the tiny EEPROM . However my main board part number is "bn41-00888c". I tried to find this online and have found different boards with the same part number. It looks like the part number is not unique for these boards.
    Does any one know how we can get the list of part numbers which are compatible for specific TV model number?
    • Geniee33
      • Jun 2015
      • 45
      yea, its a bit of a pain. only a few shops came up, but they were wayyy too expensive to justify it. considering i got the TV for $50
      • Asraf Atb
        by Asraf Atb
        01-27-2025, 05:02 PM
      • mrautom8
        Samsung TV UN75H6350AFXZC main board schematics?
        by mrautom8
        Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
        Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
        While relay is on, all voltage rails are present and steady (scoped) on main board.
        I love a good logic puzzle but getting lost without any schematics.
        No shorts on ANY capacitor main board.
        Thermal camera shows 3.3V inductor getting warm instantly but...
        10-19-2025, 06:32 PM
      • Dani_2024
        by Dani_2024
        10-28-2024, 05:06 PM
      • ygorsan
        by ygorsan
        🧩 Problem Summary:
        • I
        07-28-2025, 08:34 AM
      • Lee M.
        Samsung UN75RU8000FXZA bad main board?
        by Lee M.
        When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
        11-08-2023, 07:46 PM
