Samsung 40" LCD LA40N81BDX/XSA Main board source
  • Geniee33
    • Jun 2015
    • 45
    I have a Samsung 40" LCD LA40N81BDX/XSA which i repaired the caps on the power supply,
    The TV still wont turn on, so i attempted to reset the EEPROM on the main board.
    Well, lets just say, i made a bit of a mess, and am looking to try and replace the mainboard now.
    I cannot find anywhere that they sell this board.
    The main board is a BN94-01200F
    i have chececked ShopJimmy.com and other Google searches, but there is very little info on this board.
    I was hoping someone here may know of another source to find the board or know of any alternative boards that would also work in its place?
    I ask this because i found one ad where a guy had stripped down the same TV and was selling the main board from it, but it was a different main board code BN94-01578D
    The ad also mentioned that this board would work in a LA40M81
    Is anyone able to help?
  • lus82
    • Jun 2015
    Re: Samsung 40" LCD LA40N81BDX/XSA Main board source
    I had the same TV model and and have come across same issue. I have tried the same thing and made a mess of main board when I tried to replace the tiny EEPROM . However my main board part number is "bn41-00888c". I tried to find this online and have found different boards with the same part number. It looks like the part number is not unique for these boards.
    Does any one know how we can get the list of part numbers which are compatible for specific TV model number?
    • Geniee33
      • Jun 2015
      • 45
      yea, its a bit of a pain. only a few shops came up, but they were wayyy too expensive to justify it. considering i got the TV for $50
      • Asraf Atb
        Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
        by Asraf Atb
        Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
        Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
        I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
        01-27-2025, 05:02 PM
      • Dani_2024
        by Dani_2024
        10-28-2024, 05:06 PM
      • ygorsan
        by ygorsan
        🧩 Problem Summary:
        • I
        07-28-2025, 08:34 AM
      • Lee M.
        Samsung UN75RU8000FXZA bad main board?
        by Lee M.
        When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
        11-08-2023, 07:46 PM
      • jb_Bak
        by jb_Bak
        CN6401
        Pin 01 NC
        Pin 02 NC
        Pin 03 "BL_ON": 0V
        Pin 04 "N/C"
        Pin 05 "STBY 3.3V": 3.5V
        Pin 06 "GND": N/C
        Pin 07 "AC_OFF"...
        09-27-2021, 04:52 PM
