sanyo lcd says use pc audio fordvi when on hdmi input
  • mattstolte
    • Dec 2013
    • 612
    • usa
    this sanyo lcd when i hook it up to hdmi 1 or 2 on the screen it will say
    please use pc audio input for dvi connection
    i dont understand
    mode, number
    dp46841
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: sanyo lcd says use pc audio fordvi when on hdmi input
    Try doing a full reset to it, possibly via engineer's menu...
    'DVI' (Digital Video Interface) was the forerunner of HDMI where it didn't support audio, and had to have sound connected via a 3.5mm jack normally. HDMI was its replacement format including digital audio streams....
    Set is somehow interpreting HDMI as DVI--Like me--Its dazed and confused!
    TELEFIX
      Check the settings menu for HDMI audio input.
      • samson7point1@yahoo.com
        Help troubleshooting an audio problem with an RCA SGT-250 CED Player
        by samson7point1@yahoo.com
        The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
        The player processes the audio signal using two different reference frequencies. The "R"...
        04-30-2024, 11:22 AM
      • s_henya
        EPSON EB-X18 No HDMI input
        by s_henya
        Not my usual equipment repair, Projector works great but no HDMI input.
        motherboard: H550MA_R1
        HDMI socket was a bit chipped on the side, but no critical damage, i replaced it anyways but still no signal.
        Im assuming other damage in the mainboard.
        Can anyone give me some pointers on where to begin?...
        06-13-2025, 09:06 AM
      • rp748
        HP E233 display HDMI no input
        by rp748
        Hi
        The display is working great except for the HDMI. VGA, DisplayPort is fine.
        i have tried several cables and sources with no luck.
        Board number is 715G8912- but i didn't find its schematic anywhere.
        The main chip is RTD2526FR which i didn't find its datasheet as well.
        Main board looks fine without any blown components or soldering issues.
        When an HDMI source is connected the screen goes blank for a few seconds and then it says, "HDMI is inactive" and enters to sleep mode.
        Tested Components:
        HDMI...
        09-02-2023, 10:05 AM
      • FrancescoV
        Onkyo HT-R390 no sound output, video output ok
        by FrancescoV
        Good morning everyone,
        I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
        The firmware reported is the following:
        M:1.00/11107BLP
        D:?.??/????????
        O:1.00/11107AL
        The DSP firmware given the question marks seems corrupt.
        On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
        05-11-2025, 02:59 AM
      • reessi
        LG 42LC55 - Fixed power fault caps, now NO input on HDMI & VGA, also freezes & B/L !
        by reessi
        This TV had the well known power supply issue, took ages to turn on etc until one day it never turned on, I removed and tested all output caps on the PSU with an ESR meter and replaced the ones I've marked in blue on the photo (they are the new ones).
        After this it turns on fine but no signal is displayed when selecting VGA or HDMI 1 & 2 but the laptop always correctly sees the tv and brings up the name and resolution...
        My new flatmate assured me the hdmi's had previously worked after waiting a long time for the TV to turn on but he...
        04-30-2021, 04:28 AM
