Samsung PS51D6900DS (S50FH-YB09) power problem
  • tech2014
    • Aug 2014
    • 807
    With everything connected the tv powers up and no sound from the power supply(relay). Removed the p/s from set and shorted PS_ON and used 3.3k resistor to VS_ON and got all my voltages(VA,VS) and 5.3v, 15v. The LED doesn't come on at all, but there is 5v standby and LED on front of tv flashes red.
    I removed the YSUS and XSUS boards from the set and connected them to the p/s on my bench and p/s clicks on and I get my VS,VA VE,VSC.
    When I tried isolating the faulty board in the set, by removing connectors one at a time, I still get nothing(no relay clicks) and no LED on logic board.
    Could this point to a faulty logic or main board?
  • steviewonder
    • Dec 2013
    • 183
    • england
    Re: Samsung PS51D6900DS (S50FH-YB09) power problem
    the solenoid needs to click,to provide the switched 5v to the logic board,in every Samsung plasma I have so far come across..the green lamp should flash even with nothing else connected to the pcb,bar 5v supply.
    • tech2014
      • Aug 2014
      • 807
      I found that with everything in the tv connected, when I remove the ribbon cable going from the YSUS to the logic board, and also remove the cable going from the YSUS to XSUS, the power comes on and stays on, and the LED flashes on the logic board. As soon as I reconnect the ribbon cable or XSUS board , the power only comes on for a couple seconds then drops. the LED on the logic boards is on solid.
      I found that the 5.3v line on the power supply only measures only 90ohms.
      • PantherDave
        by PantherDave
        Hi all!
        05-29-2024, 02:01 PM
      • GLISIT
        by GLISIT
        01-16-2025, 02:29 PM
      • mrtek
        Samsung UN43NU6950FXZA No power
        by mrtek
        Hi
        Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
        Main fuse = OK
        Back light LED = OK. Power them with aux power source
        LED output = OK 156V
        I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
        Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
        07-20-2025, 08:06 PM
      • hill01
        Samsung UE75MU7009TXZG Endless Power Cycle
        by hill01
        Hi everyone and thanks in advance for any help I might get here
        My Samsung TV is about 4 years old. The exact model number is UE75MU7009TXZG.
        About half a year ago I started seeing occasional green frames pop up while watching movies. I mean literally green frames. Not the image turning green, but the entire screen turning green for a split second. This happened maybe once or twice during a 2 hour movie. So no big deal, but clearly something was not quite right.
        Since a few days, the TV won't turn...
        11-17-2021, 02:52 PM
