Samsung F5500 Grey Screen and Sound
  • anotherdude
    • Feb 2013
    • 488
    • uk
    Friend of mine has asked me to have a look at this TV, not in my possession yet but thought i'd ask here first.
    Grey screen on all inputs, menus don't show either
    tcon fault?
  • newtothis
    • Mar 2013
    • 1556
    • england
    Re: Samsung F5500 Grey Screen and Sound
    Tcon or Main
    • anotherdude
      • Feb 2013
      • 488
      • uk
      Originally posted by newtothis
      Tcon or Main
      If the set can still change channel and volume would it still be a mainboard issue?
      • newtothis
        • Mar 2013
        • 1556
        • england
        Could still be yes but more than likely Tcon
        • anotherdude
          • Feb 2013
          • 488
          • uk
          thanks for your input
            LCD, plasma?
            The F series plasmas do not have a separate TCON/logic board, it's on the main board though you can still engage test patterns.
            • newtothis
              • Mar 2013
              • 1556
              • england
              Oh yeah! Didn't realise they did both plasma and LED in the F series
              • anotherdude
                • Feb 2013
                • 488
                • uk
                it's ue32f5500, so LCD
                they missed the first numbers off and I didn't notice
                • Andrew F. Ali
                  • Jan 2014
                  • 2450
                  • Trinidad & Tobago
                  T-CON is my educated guess. Check the fuse on the T-CON for power on both sides. May just be a blown fuse on the T-CON board.
                  • Mgiffune
                    by Mgiffune
                    I have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started β€˜fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
                    I ordered a supposedly β€˜new' Tcon board this time, and
                    06-09-2024, 10:28 AM
                  • mrtek
                    Samsung UN65js8500F, no sound, blank screen and T-Con board with one LED on
                    by mrtek
                    Hi I am new to this kind of repairs but I want to learn..I have a Samsung UN65JS8500F. the TV used to work and I tried to fix darker areas in the middle only ( img 1,2,3). I thought the led strip were bad..not the case. I did not research in advance what kind and where the LED were located. In this model they are located vertically on right and left side. Took the TV apart and put it back together. Now the tv shows no welcome screen and no sound is available thru the speakers. ..just a black screen..Backlight LED do turn on...also noticed a 5 blink code , not sure if that was there before. I can...
                    11-26-2024, 09:58 AM
                  • Chrissygizmo
                    by Chrissygizmo
                    02-10-2025, 12:33 AM
                  • mar1in
                    Samsung TU8000, backlight and sound on, stuck in blue screen
                    by mar1in
                    I've got this Samsung here that would be stuck in a boot loop.
                    After opening up and doing the tape block method, I was able to get it to turn on and play sound from the HDMI input, but with a blue screen.
                    Does that mean there is another combination of pins that I need to block in order to get a picture, or is there something more serious, faulty mainboard or faulty panel?
                    Thanks in advance
                    11-08-2023, 05:43 PM
                  • Chrissygizmo
                    samsung galaxy ao2s very temperamental after screen replaced
                    by Chrissygizmo
                    Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                    Ive eventually managed to get it on and working but it's very temperamental...
                    The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                    05-26-2024, 12:05 AM
