LG 47LN5400 TV Backlight problem
  • SurrealMustard
    • Jan 2015
    • 486
    • The United States of America
    #41
    Update
    The two L2 Led strips arrived and I installed them right away. I also used the remaining good Leds from the strips that were replaced to replace the bad ones on the other strips throughout the set and now everything is working 100%!
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8146
      Re: LG 47LN5400 TV Backlight problem
      Perfect!
      • Thorn
        • Nov 2016
        • Us
        #43
        Same issue here. Sound still see picture but no back light. traced it back to bad LEDs, replaced all. Problem still persisted, replaced power supply just in case it had some unseen issue(I believe the inverter is part of it) no change.. Tore it back down to LEDs, turns out one led bad on one strand...these were brand new! :/ got a replacement for that strand, tested all LEDs again,all test good now, but problem persists!
        One thing that is happens when you turn it on now and you get the notorious "flash, then nothing" 3 led strands are not flashing up even though they test good with direct power Scratching my head. I tested all LEDs, output voltage on PSu, and tested on the leads on the ribbon cable from the main board, all voltage seem right except the bottom lead on ribbon(blue cable ) tested 3.27v where it is printed 3.5v specs? Is there some small issue on the main board?
          What are the spec of the replacement LED?
          • Dobrowol
            Asus GA402RK keyboard and kb backlight problem
            by Dobrowol
            Hi. I have a problem with Asus ROG GA402RK. The keyboard suddenly stopped working along with the kb backlight. I replaced the keyboard and the ITE KBC chip and the problem is still the same. I don't see any passive elements that look damaged. Does anyone have an idea?
            04-28-2025, 04:30 PM
          • ononos
            LG M2362DP Backlight problem
            by ononos
            hello everyone!
            As the title states i am an owner of an LG flatron M2362DP 23 inch monitor Tv. Since i currently use it as a tv i'm posting the problem on the "troubleshooting tvs and video sources" section.
            I'm from Greece so English isn't my native language, so please forgive me for any mistakes i make. I have basic knowledge in electronics, and although i have a degree, many things have changed since i finished a 2 year coarse (over 30 years ago). Occasionally i repair easy stuff, mostly things that break at home like appliances.
            So i decided to try to...
            03-12-2023, 05:05 AM
          • fanaticgames
            Samsung UE32D4010 Backlight problem, led ok
            by fanaticgames
            hello I have a backlight problem on this TV, if I unplug the cn201 cable the backlight works perfectly and the voltages are 13v if I connect the cn201 cable the backlight goes off and the voltage drops to 12v, I assume it's a motherboard problem, the question is has anyone had a similar problem? I want to understand if the motherboard is repairable or it's not worth wasting time...
            02-22-2023, 09:46 AM
          • Honziq
            Backlight problem - Asus M3200WU, board Gapal LA-L291p
            by Honziq
            I have this All-in-one PC, after SSD change there is no picture. I was found out it is a backlight problem, but LEDs are OK. There is 4 led strings each working on 42,4V, but from board is comming only 5V.
            I was repaired many backlights before but this design i will not understand.
            For me it looks like it is waiting for some signal from screen to start up the backlight or something like this. Nothing seems to be damaged or shorted here.
            Can someone explain me please what to do, what to check?
            Thanks....
            11-20-2024, 01:24 PM
          • grbo92
            Backlight problem Acer LA-031P
            by grbo92
            i have one acer Nitro 5 without backlight on my desk.
            Mainboard model: LA-L031P GH53Z REV 1B
            Attached schematics and boardview are REV 1A, slightly different as REV 1B.
            11411_LA-L031P-Acer_Nitro_5_AN515-45_AN517-41-GH53Z_Rev_ (1).zip
            Repair history: customer cleaned dust and changed thermal paste, shortly after that there was no light
            Notebook boots without problem and shows only image without backlight, HDMI output working. Optical inspection done, no burned or broken components. Tested also with a new display module....
            09-09-2024, 03:49 AM
