Samsung tv blinking panel light
  • chiefdan
    • May 2015
    • 10
    Samsung TV LNT3242H Power board BN44-00192A (MK32P3)
    Problem: No picture, no back light, no sound, just front blinking red light
    I have been looking at this tv for about a week now as a novice, and can't find anything wrong. I have tested all caps visually and with ESR and cap meter. Can't find any bad ones. I have tested all diodes some in circuit, some out if they tested positive both ways, but found no bad ones. I replaced the large resistor RM801 with a 2w but the original was not bad. It had that glue crap all over it and the caps next to it, but had no carbon lines. Other places on the board had the burnt glue, but no carbon lines anywhere.
    I had thought the Mosfet CP801S might be bad because I could never get a good reading on it, so I just put it back in.
    I took the ribbon cable between PS mainboard and jumped I did have 5 volts on the SB. After jumping I had the following voltages;
    Mainboard cable
    12.3v @ 12v pin 7
    5.3V @ 5.3 pin 13
    5.3v @ 5.3 pin 15
    12.1v @ 13V pin 19*******
    12.1v @ 13v pin 21*******
    12.0v @ 12V pin 4
    5.3v @ 5.3v pin 14
    5.3v @ 5.3v pin 16
    12.1v @ 12v pin 22
    small ribbon coming from main board
    det 5.14v
    pwm 4.25v
    adm 002v
    blu .009v
    cable going to inverter
    pwm 4.25v
    adm .002v
    bl .011
    nc .311
    all 24's had 24v
    leg of RM801 323.4V
    leg of DB851 5.22v
    leg of bridge (with negative meter lead clamped to ground screw)
    DC- 57.9v
    DC+ 59v
    With meter negative to negative leg of bridge 117dcv
    I also took the t-con out to look for blown fuse, but could not find on on the board. I also jumped the back light board and it came on.
    So that's kinda where i'm at. Any of your expert tuteledge would be greatly appreciated. pictures attached.
    Re: Samsung tv blinking panel light
    "leg of RM801 323.4V
    leg of DB851 5.22v
    leg of bridge (with negative meter lead clamped to ground screw)leg of bridge (with negative meter lead clamped to ground screw)
    DC- 57.9v
    DC+ 59v
    With meter negative to negative leg of bridge 117dcv"
    When you check the DCV on the primary side, you cannot use the chassis/safety GND as the GND ref for the meter, you have to use Negative leg of the main filter cap as the GND ref point.
    You should have about 160VDC between the two legs of the main filter cap, it should jump up to >360VDC when main board sends the PS-ON to turn on the PFC Voltage booster circuit and the rest of the power supply.
    "bl .011" Right now the main board is not sending the BL-ON signal to turn on the backlights.
    • chiefdan
      • May 2015
      • 10
      Thank you for you reply budm. Voltage across the large capacitor is 158v when ps is not jumpered. With the ps jumpered, the voltage goes to 383v. Is it your opinion the main board is bad?
      • Shinju
        • Mar 2014
        • 1239
        Just an fyi, Samsung panels do not use a LED error code system. a blinking LED on the front of the panel is normal for all Samsung units and means nothing.
        • Hamie
          • Apr 2014
          • 1383
          Yes mainboard isn't sending ps-on or bl-on signals.
          • chiefdan
            • May 2015
            • 10
            Re: Samsung tv LNT3242H blinking panel light
            Thank you Hamie and Shinju for you reply. I really appreciate it.
            • matty24
              Samsung UE50MU6172 - red light blinking
              by matty24
              Hello. I have problem with Samsung UE50MU6172.
              TV won't turn on, red standby light is blinking.
              Power supply BN44-00807A is fine. I replaced it with the new one.​
              Main board BN41-02568B (BN94-12530E)
              I've read a dump (W25Q40CL). Can someone check it od fix it for me?...
              03-02-2025, 08:57 AM
            • Fergal22
              Samsung UE40F5300AK blinking red light
              by Fergal22
              I have the above tv that just shows a red light blinking twice 5 times, i have taken the back off and all the capacitors seem ok,
              When i disconnect the mainboard from the PSU all the led's light up blinking fast but as soon as i reconnect the mainboard back to the power supply i get the red light blinking again twice 5 times,
              I have attached pictures of the Mainboard, PSU and a small video (zipped) showing what happens when i disconnect the lead from the psu
              Any help would be appreciated...
              02-02-2023, 09:19 AM
            • norbiszoke
              Samsung 50AU7172, only blinking red light
              by norbiszoke
              We have this set here in our shop that is not ginving sign of life besides red light that is blinking one time after pressing the button and nothing more... After detaching the mainboard from the PSU (this set has separate board thank god?! or not...) the backlight comes on. After reattaching nothing besides red light.... Can anyone from the forum help me here? Thank you in advance. Here's a link with images of the mainboard and the memory IC's that are on it.
              Regards, Norbert!...
              04-17-2024, 06:54 AM
              09-07-2024, 05:50 AM
            • 3DDD
              Samsung UE46D6100 LED TV blinking red light indicator
              by 3DDD
              Hello, I have a Samsung UE46D6100. It cannot be turned on, only the red status LED flashes, the power supply part bn44-00458a gives an output of 5V(A), it is probably functional. I don't know where to look for the error, according to the video it should be a faulty mosfet. I found a mosfet marked WAAH, I don't know what it is. Can anyone help me?...
              02-20-2025, 12:51 PM
