sharp_lc32ga9e wont power on
  • ammarben
    • May 2013
    • 63
    • algeria
    i have a sharp_lc32ga9e that wont power on
    when i put it in AC the red led flash for 1 seconde than go off
    if a press the power the green led comes than the relay click and after 5 s the led off no standby red led and nothing else hapen
    when i test the power supply alone all voltage are present
    can it be a corrupted flash?
  • sordids999
    • May 2013
    • 2161
    • uk
    Re: sharp_lc32ga9e wont power on
    Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
    • ammarben
      • May 2013
      • 63
      • algeria
      i have no camera sorry
      i check evert thing tested all supply voltage are correct
      isuspect the main bord till there is no standby red led
      but when i press power green led come ,relay click than green led off thats all
      when hold the volume down and the input buttons (on set) whilst plugging in the AC lead i did once get the backlights to come for 1s nothing else
      how to now if it is the main
      • ammarben
        • May 2013
        • 63
        • algeria
        canyou help me to flash this set?
        • ammarben
          • May 2013
          • 63
          • algeria
          update
          pcon1 and pcon2 are present 3.3v but no inv-on
          • ammarben
            • May 2013
            • 63
            • algeria
            here is the service manual
            • ammarben
              • May 2013
              • 63
              • algeria
              i have the same set as this thread
              https://www.badcaps.net/forum/showth...ht=sharp+aquos
              pls tom66 you have answered this
              I think firmware may be corrupt, no reset will cure that. The "I2C" method may be necessary
              how to do that I2C method
              • Andrew F. Ali
                • Jan 2014
                • 2450
                • Trinidad & Tobago
                You can probably try this method. On the Main Board search and locate the EEPROM IC. It would be an SMD 8pin IC SOP-8. It will be the 24C64, 24C128 or 24CXXX ICs. (I did not look at the SD for this TV)
                Look up your EEPROM IC number and determine the pin configuration
                Five (5) easy steps
                1. With the TV OFF solder a jumper across the VCC pin and the SDA.
                2. Power ON the TV for 20sec. (You may see an error message on the screen)
                3. Disconnect the jumper at the SDA pin and switch OFF TV.
                4. Remove the other end of the jumper from the VCC pin.
                5. Now power ON the TV, it should perform normally.
                • ammarben
                  • May 2013
                  • 63
                  • algeria
                  thank you dear Andrew
                  but the problem is that the tv won't Power ON it do for less 3 or 4 sec so it can not let me reset
                  the VHI24LC2BIN-1Y sharp eeprom
                  and there is no display
                  • Andrew F. Ali
                    • Jan 2014
                    • 2450
                    • Trinidad & Tobago
                    There is a method to self test the Power Board. Do you know this method?
                    • ammarben
                      • May 2013
                      • 63
                      • algeria
                      hi Andrew can you teach me this self test method pls?
                      • Tynan Dill
                        by Tynan Dill
                        Assuming...
                        11-22-2024, 01:46 PM
                      • PantherDave
                        by PantherDave
                        Hi all!
                        05-29-2024, 02:01 PM
                      • GLISIT
                        by GLISIT
                        01-16-2025, 02:29 PM
                        03-31-2024, 02:12 PM
                        09-06-2024, 05:59 AM
