I have a Vizio P50hdm and when I turn it on it shuts down after 2 seconds. During those 2 seconds I hear a fizzing noise coming from the power supply before it shuts off. Using my multimeter, I checked the Vs and Va voltages on the power supply board, and I got less than 3 volts going to the X and Y sustain boards. The standby voltage is fine which is at 5V. The sticker on the TV says that the Vs is 196V, and the Va is 60V. So is it safe to say that the power supply is the problem and should be replaced? I disconnected the X and Y sustain boards one at a time and the TV still shuts down so I know that it probably isn't those boards. What do you think it is? I think it's the power supply. Any help would be greatly appreciated. Thanks
Vizio plasma TV issue HELP!
Re: Vizio plasma TV issue HELP!
I think these shutdown with the boards disconnected . Did you backprobe Vs and watch it as you powerup? may see vs for a moment. LG panel and boards and that series blows the IPMs on both the Ysus and Zsus so if they're dead and shorting Vs then that may be the noise from the PSU.
I know on the LG it will go to power on for a second or twn then fault back to standby.
probably not economical to repair these now, ipms are not that cheap and all 4 should be done if one has failed from what I've read if you do one you could be back soon after as they're all the same age.
search the panel number, ysus and zsus board numbers, ipm numbers eg yppd-j016 etc and there should be quite a few threads. I think Toshiba and Sony plasma used the LG panels too at the time so there'll be plenty of info spread over various barndsLast edited by tw2005; 05-22-2015, 10:17 PM.Comment
I did test the Vs while powering it up and it read over 300V then it immedialtly goes down below 3V and starts going down slowly. This is the same case for the Va. I think the power supply is not supplying the right DC voltage to the sustain boards. I also don't see any bulged capacitors on either board. I actually tested the fuses and one of them were bad on the y sustain board.Comment
Not saying you can't have bad psu but bad sustains is highly likelyComment
Err-----
WHY on Earth have you started Yet Another thread on this same set with same fault?
You HAVENT got back to us on the recommendations I said in the first thread! All you're doing is wasting time for yourself--and everyone else!!
First Thread--
https://www.badcaps.net/forum/showth...436#post561436TELEFIX
PLEASE DO NOT EMAIL ME PRIVATELY FOR REPAIR ADVICE. QUESTIONS BELONG ON THE FORUM!Comment
Err-----
First Thread--
https://www.badcaps.net/forum/showth...436#post561436Last edited by froylan_m; 05-23-2015, 08:20 AM.Comment
Well--I'm just trying to help. IF you need to revive--what you may think is a dead-thread, its better to make a reply to it stating any tests etc you've tried.
--Everything then is in the same place for easy reference to those looking on--who then may have an idea to further the Cause....
In your current case--You say you have 300V Vs dropping to 0 after a time.
LG PSU's when Unloaded DO overshoot (Would doubt to over 300V though, about 250V is the over-volts trip on 'em--Check your meter!)and then auto-protect shut-down.
--IF you need to check Just the PSU, disconnect the SUS boards from the PSU--Leave everything else connected and take a 240V 150W Bulb and connect it from the Vs pin of PSU to chassis or ground connection pin of PSU at the same plug.
Run the set--Lamp should light and the voltage should be within panel label spec...
IF you have blown fuses on Y-SUS and/or X-SUS then there's surely a short on an IPM. Replacing the fuse will not cure it, just waste a good fuse.
You need to check the IPM's for short-circuits. Google search testing L.G. IPM, there's various tests that can be done.TELEFIX
Ok so I disconnected the X sustain board with the Y sustain plugged in and the TV still shut down, but when I turned it on again and it stayed on. I think the first time it didn't turn on because it detected a disconnected board, but it turned on the second time. When it was on I tested the power supply and it was good actually. Then, I reconnected the X sustain board and the TV shut down both times. So I think the problem is the X sustain because it prevented the TV from turning on. What do you think?Comment
So--Have you checked the IPM's for shorts or not....?TELEFIX
by MectronikHello, I'm working on a Vizio m601d-a3 with a backlight issue that I am having a difficulty diagnosing it. As it sits, the tv powers on, displays the Vizio symbol and with nothing hooked up it will then display no signal but you can only see half of the screen. I know it's a back light issue because the picture is there without light behind it, as I can see it by doing a light test. I've taken off the paneling and done a visual inspection. If I disconnect the tcon ribbon cable to the affected side then the entire half of the screen goes away. I've checked voltages at the LED driver from the main...
by EazyBoneGot this TV free. Guy said it tries to turn on and doesn't. I haven't seen this specific issue before but shown in video. Any way to test the screen to rule it out on these Vizio? Or anyone seen this issue before?
Any help appreciated
https://youtu.be/tPeV2Q7TXIQ?feature=shared -
by remmurdmdHi everyone. First new thread here. I picked up a TV on the side of the road. It appears to function correctly with the exception of an image issue I'm unable to describe. I've searched for “double picture” and “double image” all over the web and all I get is repair videos for when the picture is blurry and the connections are getting interference between the display panels and the t-con board. I believe this is a t-con board issue, but I haven't found anything telling me conclusively that this is where my issue is. I'd appreciate any assistance you can provide. I live a pretty busy life...
I have a 42" Vizio TV. I hooked my tablet to the HDMI inputs. Everything was fine until the screen went black and now the only input that works on the TV is coax. No hdmi, no component, no rca. I tried hooking up a laptop to the Hdmi port and the computer
detected the TV model but no image.
Is there anyone having the same issue? Did you find any solution?
Good morning BadCappers,
I picked up a Vizio E60-E3 yesterday. The donator claimed that it never powered on and that he checked Voltages at the power supply. I checked a handful of Voltages and then laughed when I realized I was trying to turn it on via the menu button on the back of the TV when its upside down on my TV repair bed (literally my guest bedroom).
Okay so I took out the mainboard and decided to flux up the BGA and heat it up. Upon reinstall of the mainboard the TV does indeed power up but all of the screens have a blue hue AND the video displayed fails... - Loading...
