Prima 4237P Plasma TV power issue
  • tech2014
    • Aug 2014
    • 807
    This is a PDP tv. If it is left unplugged for a while, it will power up fine and all voltages are present. If it is turned off, it won't power up again. The voltages are there for a few seconds except for the VS, it just goes to 60v then down to about 1-2 volts. I resoldered all the parts on the heat sinks of the power supply and still no luck. Anyone ever worked on one of these before? Also, anyone know where I can find a service manual?
  • Cooperr
    Samsung 59" plasma PN59D550C1F seeking advice on mystery power board issue
    by Cooperr
    I picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
    The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board...
    10-21-2025, 01:11 PM
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • lp20th
    Samsung Plasma TV Power Supply Issue
    by lp20th
    I have a vintage 2008 Samsung 50” Plasma TV, Model code PN50A550S1FXZA with a power supply part number BN44-00222A. I repaired the power supply board several years ago finding a couple of cold solder joints on the back side of the board and it's worked great up until now. Recently a fried sound occurred with the smell of burnt electronics and the TV shut down. Trying to turn it back on yielded the typical relay clicking with no TV boot up. Upon investigation, removing feeds to the other boards within the TV it was found that disconnecting the logic board from the power supply allowed the...
    11-28-2023, 10:28 AM
  • yaya3gmax
    Laptop Power Issue – Works on Battery, Fails on Adapter Load
    by yaya3gmax
    Dell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
    Symptoms:
    • Laptop works normally on a pre-charged battery.
    • Battery does not charge when adapter is connected.
    • Without battery:
      • Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
      • Speakers “pop” when power cut occurs indicating harsh sutdown.
      • If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
    08-21-2025, 07:16 AM
  • Capacitorial
    Powersupply has all the voltages - Monitor still no power
    by Capacitorial
    Hello guys,
    I have a Philips 240B7QPJEB. The monitor seems completely dead.
    I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
    On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
    The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
    The weird thing is, that the Power LED is powered over the TCON board.
    On The TCON...
    12-28-2024, 02:12 PM
