LG 42PG20 - has sound - no picture
  • r4zorsoft
    • Feb 2015
    • 11
    Currently I'm troubleshooting an LG 42PG20 plasma television.
    I'm able to confirm that sound works through the three HDMI ports, connected to my PC graphics card.
    I hear a "click" when the TV is plugged in, when it is turned on, and again when the TV is turned off. The red standby light on the front of the TV turns blue when "on".
    At no point does the panel energize/prime - I have blackout curtains in my room, and cannot see any glow whatsoever coming from the panel while testing.
    Initially I assumed the problem was the Y-SUS board (original part number: EBR50221404), so I replaced the board. The new board was indicated to be compatible per the reputable parts vendor (replacement part number: EBR54740702), but replacing the board unfortunately did not resolve the problem.
    The original power board (part number: EAY43533901) provided the following readings on my multimeter:
    • Vs: 3.43V
    • Vs: 3.43V
    • NC: N/A (no pin)
    • GND: 0.00V
    • GND: 0.00V
    • VA: 0.88V
    • VA: 0.88V
    • GND: 0.00V
    • M5V: 0.00V
    • M5V: 0.00V
    Definitely out of spec when compared to the voltage listing from the LG repair manual (see first image attachment). The manual I referenced is located at this documentation PDF
    I installed a new power board (replacement part number: EAY39333001), also different but confirmed to be compatible. Current voltage readings are:
    • Vs: 192.6V
    • Vs: 192.6V
    • NC: N/A (no pin)
    • GND: -1.2V
    • GND: -1.3V
    • VA: 59.6V
    • VA: 59.6V
    • GND: -0.6V
    • M5V: 5.09V
    • M5V: 5.09V
    Despite replacing both the Y-SUS and power boards, there is no change - still have sound, but the panel does not energize/prime.
    The images attached display the replacement boards installed in the TV (parts EBR54740702 and EAY39333001).
    The main board images are included to show:
    • No power
    • Standby
    • Powered on (green light on the left turns off after a few seconds)
    I still have the original boards, and can provide pictures of those if necessary.
    At this point, I am not sure what to do. Kindly advise as to what I should test next.
  • vicvc
    • May 2015
    • 13
    • south africa
    Re: LG 42PG20 - has sound - no picture
    referring to your manual page 20 bottom can you measure vscan(vsc),-vy,zbais and post the values?
    • r4zorsoft
      • Feb 2015
      • 11
      Thanks for your response. My apologies for my late reply. Had to move my things into storage for the past year due to life circumstances.
      I took readings as you suggested:
      vscan: 139.6V
      -vy: 186.8V
      zbias: 81.5V
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Lol but of a big delay there haha. Hope all is well Also have you tried the test patterns ?
        • r4zorsoft
          • Feb 2015
          • 11
          Things are going better, thanks!
          I have not tried the test patterns; the panel does not glow at all in a pitch-dark room. I get the loud relay click when plugging in the power cable and turning it on/off, but there is no light from the panel at all.
          • ChaosLegionnaire
            by ChaosLegionnaire
            09-13-2022, 09:02 AM
          • LEECH666
            Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
            by LEECH666
            Good day ladies and gentleman!
            I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
            This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
            I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
            01-19-2024, 05:46 PM
          • Christos Tsiligiannis
            Marian Trace Alpha sound card repair help
            by Christos Tsiligiannis
            Hello to the forum.
            My name is Christos, I am new to the forum here and i am posting from Greece.
            So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
            To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
            So i tried asking for a schematic from the company and they would not give me one. Instead they...
            11-18-2024, 05:26 AM
            HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i7-9700 Specification for Upgrade or Repair
            This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
            09-12-2024, 02:30 PM
            HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500 Specification for Upgrade or Repair
