Sony Kv21Se42 stby light displays 4 blinks.
  • SEAWOLF
    • Nov 2011
    • 177
    • Barbados West Indies.
    I recently replaced 3 elec capacitors in the vert circuit of a Sony Kv21se42 with
    the stand by light blinking 4 times.When the tv was powered up,there were
    vertical lines on the screen and I replaced the ver IC and the television worked
    ok for 3 days and shut down again and stby light is blinking 4 times.
    Can anyone offer a solution for this problem?
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Sony Kv21Se42 stby light displays 4 blinks.
    I would check the Hor Osc cct for cold solder joints, also. Hor Osc Transformer, transistor, Horiz Output Transistor, Horiz Osc IC, etc. Ther may even be a Hor Osc Crystal that may be faulty.
    • Elecfronicsssss
      DA0NJJMBAG0 charging light blinks
      by Elecfronicsssss
      Laptop motherboard DA0NJJMBAG0
      PROBLEM-WHEN I PLUG THE CHARGER WITHOUT BATTERY THE CHARGING LIGHT BLINKS AND WHEN I PRESS POWER BUTTON THE CHARGING LIGHT STOPS BLINKING AND STAYS ON BUT THE POWER LIGHT DOESNT TURN ON AND LAPTOP ALSO DOESNT TURN ON NO FAN SPINS NO KEYBOARD LIGHT.
      CHECKED- ON S5 STATE TGE LAPTOP HAS 5V ON USB 3.3V BUT I DIDNT GET 1.8VOLTS ON BIOS PIN NO 8 WHILE PLUGGED IN AND EVEN ON S5 STATE.
      GUIDE ME WITH THE PROBLEM..
      SUMMARY-
      1.NO 1.8VOLTS ON BIOS PIN NO 8.
      2.S5 STATE ((PRESSING POWER BUTTON)))VOLTAGES ARE PRESENT...
      05-12-2025, 02:32 AM
    • SkishyIshy
      Sony Bravia XBR-65x900f: No Power, No Standby-light - however 3.3v STBY is present
      by SkishyIshy
      Hey All,
      I have a Sony 65x900f that I purchased cheap because of a no-power issue.
      I assumed that because there is no standby light visible, it would be an easy fix - however upon opening up of the unit I can confirm that the 3v3 standby voltage is making it's way from the power supply to the main board. I'm a little confused as to why there is no standby light.
      I am firstly wondering if anyone has this model of TV, or has worked on one and can give me some insight. I have tried to find a service manual for this model, to no avail - and would really appreciate...
      03-17-2021, 11:44 AM
    • AK_777
      Sony KD-65A1 Repair – 4 Red Blinks Error
      by AK_777
      Hi everyone!
      I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
      Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
      02-20-2025, 04:15 PM
    • jchon
      Sony A1e 5-blinks help
      by jchon
      Hi I'm new to trying to repair TVs, but I saw a broken OLED offered for a reasonable price and thought I'd try my hand at it.
      I found the service manual, which was critical to know where to probe.
      https://www.manualslib.com/manual/20...1e-Series.html
      With it I was able to determine that my DKA board was bad, when P_ON#1/2 gets enabled REG_12 on the DKA board collapses. I'm assuming one of the downstream regulators has a short, but I couldn't work out which rail/component and replaced the DKA board entirely.
      Unfortunately the 5-blinks...
      06-28-2023, 11:52 AM
    • thstuff
      Sony OLED XR-77A80J - Initially dead, now 4 Flashes
      by thstuff
      A) TV initially dead
      B) On a hunch of a locked up Google OS, plugged in a USB memory stick with latest FW and plugged it in. It booted into the update screen, completed the update and restarted to Home screen.
      C) Was able to perform a Reset from Settings menu and completed out of box configuration.
      D) Ran a 4K screen saver demo for about 6 hours, then turned it off for the day. Did not notice any stripes, dead zones or other artifacts in the image.
      E) Powered back on and it now runs for a few minutes before relay clicks, screen goes blank, Main Board Red Digital Optical...
      12-26-2024, 09:10 PM
