Samsung PN51D550C1F -X and Y Main board replacement
  • tech2014
    • Aug 2014
    • 807
    I have a tv I tried component repair on as the customer didn't want to pay for the board replacement. He has now decided to do board replacement. What I want to know is if I should replace both the x and y boards as typically when one goes it usually takes out the other. The original problem was a power issue. I got the tv working with all voltages, but 1 of the iGBT transistors keeps blowing on the Y main board after the tv is on for a while. not sure if its a buffer problem too or if I missed something, but I want to do board replacement.
    Should I replace both? I can't find the exact match for the y main. I need a rev 1.3 but all i can find is 1.2.
    Re: Samsung PN51D550C1F -X and Y Main board replacement
    Do you have the 1080p boards installed? It's important, as the 720p boards are similar but *will not* work in this set properly.
    • tech2014
      • Aug 2014
      • 807
      yes they are 1080p. I can't find the right board. The x main I need has 4 caps on it and the one I am finding has only 3 and it is a rev 1.2, I need rev 1.3
        The 3 cap ones are the 720p models anyway.
        • tech2014
          • Aug 2014
          • 807
          thanks Tom. So I found a used Y-main(LJ41-09423A) on ebay for $66. I can't find the X main(LJ41-09422A) on eBay, it only has the 720p board. I can order the X main board through samsung but they want $130US plus shipping. Any idea where to get the other board used.
            Nope. It's a frequent failure so you'll have to rebuild it.
            • munja
              • Apr 2015
              • 5
              • Serbia
              http://www.exporters.sg you can buy x board
              • tech2014
                • Aug 2014
                • 807
                thanks tom. Its pretty much rebuilt already lol.
                • Asraf Atb
                  by Asraf Atb
                  01-27-2025, 05:02 PM
                • ygorsan
                  by ygorsan
                  🧩 Problem Summary:
                  • I
                  07-28-2025, 08:34 AM
                • PMan976
                  Samsung Main board replacement-bn94-07217N
                  by PMan976
                  I have a Samsung TV that has a bn94-07217N main board. I am having a hard time finding the N version of the board but I can find Ver K and Ver F boards. Does anyone know what the differences are and whether they are interchangeable?
                  I was told that the N ver is a Canadian version.
                  If anyone has any information on the Samsung versions it would be appreciated.
                  06-13-2023, 03:02 PM
                • Lee M.
                  Samsung UN75RU8000FXZA bad main board?
                  by Lee M.
                  When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
                  11-08-2023, 07:46 PM
                • jb_Bak
                  by jb_Bak
                  CN6401
                  Pin 01 NC
                  Pin 02 NC
                  Pin 03 "BL_ON": 0V
                  Pin 04 "N/C"
                  Pin 05 "STBY 3.3V": 3.5V
                  Pin 06 "GND": N/C
                  Pin 07 "AC_OFF"...
                  09-27-2021, 04:52 PM
