Samsung LNT5265fx psu both fuses blown
  • hawaiianeye
    • Nov 2014
    • 37
    • Hawaii
    i really want to fix this nice TV. it has no scratches on the screen and it seems like its just the PSU. i can only find it for around 100$ so i would like to try to fix the PSU first before that. i dont think im going to find a 52 inch samsung like this with a good psu and a cracked screen to swap psu's anytime soon so this is a good one to learn on with a big reward (for me anyway) if i can get this going. where do you start when you have both fuses blown?
    for some reason i have a gut feeling that when fuses are blown, a simple cap replacement probably wont fix it?
  • selldoor
    Slow Learner
    • 7870
    Re: Samsung LNT5265fx psu both fuses blown
    You need to post good clear pictures of both sides of YOUR boards.
    First item to check would be a bridge rectifier or a goup of 4 diodes.
    Also search for Dim Bulb Test which is useful in not causing more damage.
    Any Idea if it was hit by electric surge or lightning strike.
    • hawaiianeye
      • Nov 2014
      • 37
      • Hawaii
      have no idea on the history of this tv. ill get back with better pictures soon, and search that dim bulb test. thanks!
        09-07-2024, 05:50 AM
      • cheeky2
        Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
        by cheeky2
        This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
        I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
        Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
        06-15-2025, 05:12 AM
        Surface Mount Fuses Fundamentals Datasheet
        TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
        TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
        10-07-2024, 06:07 AM
      • MrzPdlch
        Blown fuses on Gigabyte GTX 980TI 6GB
        by MrzPdlch
        Hey everyone,
        I just went ahead and unscrewed a faulty GTX 980 TI from Gigabyte. What I found beneath the cooler was, as it seems, a common issue of that card. Two blown fuses on the bottom right corner of the card next to a MOSFET.
        Now my question would be if there is any schematics of that card available to figure out which are the blown components so I can try and replace them together with the mosfet if needed.
        Find some pictures of the actual GPU together with a picture of how it should look like.
        I also wonder whther it might be a problem that there...
        03-10-2024, 04:14 PM
        09-06-2024, 11:40 PM
