Polaroid TLAC-02255 22 inch TV repair
  • gsimpson2g
    • Apr 2015
    I recently picked up a Polaroid TV for cheap. The owner had been using it as a computer monitor, and said that after a thunderstorm, it will now randomly turn itself off. I tested it on HDMI, and it will stay on a few minutes, then turn off. I also found that when trying to adjust the resolution from my computer via the HDMI port, it would turn the TV off immediately. When it turns off, there is a loud pop heard through the speakers. It will turn right back on without having to wait or unplug anything, then repeat the turn off after a few minutes.
    All capacitors look good on both the main board and power board. No bulges or leaking on any of them. I was also able to perform simple tests on the caps with a volt meter, and was able to see the resistance increase while the probes where connected to the caps, though on the main board, a few would show a constant, low resistance.
    My question is, do the symptoms sound like a shorted capacitor? What other components can I test with just a digital volt meter?
    • 31198
    Re: Polaroid TLAC-02255 22 inch TV repair
    do a "finger test"
    put a finger on each chip - obviously NOT on the psu/invertor board.
    see if any are getting seriously hot.
    it's not going to be a capacitor if it was lightning - it's going to be silicon or a firmware/eeprom corruption.
      How about good clear pictures of the whole backside of the TV, the boards, the connectors of the boards?
      • cind12
        GTX 1080 TI Gigabyte Aorus low resistance on vmem
        by cind12
        Hi guys, i was wondering, i've got 9Ohms on Vmem, one of the mosfet was shortet to ground, so i've desoldered hi and low mosfets nad still low res, then i removed all of the memory chips, and the resistance is still low, so did you had maybe a card with that low res on memories, and the card was working fine ?
        Removed the U1866Q and still without result, i dont have thermal cam so can't see where is hot spot when incjeting voltage.
        The resistance on core is ok 0.1Ohm ((Power 0.8V when on)
        Resistance on 12V 4K ohms (Power present when on)
        Resistance on 12V PEX 4K ohms...
        12-08-2023, 09:09 AM
        HP ZBook Firefly 16 inch G10 Notebook Specification for Upgrade or Repair
        This specification for the HP ZBook Firefly 16 inch G10 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 inch G10 boardview and 16 inch G10 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
        09-07-2024, 07:20 AM
        09-07-2024, 07:19 AM
