Panasonic TX-P42U10E 7 Blinks
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Re: Panasonic TX-P42U10E 7 Blinks
    Ok , i will see if i can find the same chip on one of my SU boards and replace it.
    Probably hard to desolder?
    • tw2005
      • Oct 2011
      • 6458
      These may only be 100 pin which would make sense since they use 8 chips. The 2010 models dropped to 6 but 128pin. Without hot air I would say you have a tough job. Remember that silicone adheres the chip and is underneath it. Removing to discard is one thing but to get one off and re-use, that's a challenge. Good luck
      • Moreno83
        • Jun 2014
        • 2008
        • The Netherlands
        Thx , will let you know the outcome!
        • Moreno83
          • Jun 2014
          • 2008
          • The Netherlands
          Ordered the part from "flattvparts.co.uk" . Fast shipping but 1 of the chips on the board has a short and i still get a 7 blink error. Hopefully i get my money back.
          • Moreno83
            • Jun 2014
            • 2008
            • The Netherlands
            The tv stays on when i use the jumper.
            Can it be that i shorted this board immediately when i turned the tv on for the first time? ( all screws inserted ).
            Or did i buy a defective board? What are the chances?
            • tw2005
              • Oct 2011
              • 6458
              Flattvparts are not very good at checking their items. I've had several boards from them arrive DOA , even after asking them to check prior to shipping and giving them instructions on where to check. this was a few years ago now.
              They were well priced then.
              Then they had a policy of the boards needed to be returned but for international they agreed that since the cost was excessive then they'd refund with evidence of the board destroyed.
              I ended up lodging Paypal claim and eventually got my money back but i also had an email trail which showed I had discussed board tests. They were slow to act but i got what I wanted and ended up with a core board which now lives on thanks to me working out component level repair.
              be careful fitting shorted buffer boards they can pop the SC.
              Most of my stuff I get from payless components US. Been pretty good but did get a DOA. Got full refund with little effort and they did test some boards just before shipping at my request since I pointed out it was in their interest too since they refund the shipping. very good aftersales service.
              Stocks of good used boards are dwindling for the older models so getting harder to pick and choose who you deal with.
              • tw2005
                • Oct 2011
                • 6458
                Always check these yourself first. never trust what has been sent is good. Doubt you killed it unless the panel is shorted.
                Odds are they sent you dud board going on my biased opinion of FlatTV
                • Moreno83
                  • Jun 2014
                  • 2008
                  • The Netherlands
                  #28
                  Thx for the detailed reply!
                  I had good hopes for "flattvparts" but I'm really disappointed. On arrival i inserted the board , checked all screws and turned on the tv and it went straight to 7 blinks. Only 1 chip is shorted but its to hard to repair , harder then A-15 chip.
                  Hope i get a replacement or my money back!
                  • tw2005
                    • Oct 2011
                    • 6458
                    yeah, sometimes you don't know until you have a go. Did you try and damage the board or bailed out for a used board?
                    • Moreno83
                      • Jun 2014
                      • 2008
                      • The Netherlands
                      #30
                      I tried to repair the old board but i had difficulties removing the chip , damaging more then repairing
                      So when i failed removing the chip i bought the replacement board , unfortunately its also the weekend so monday will probably be the first hope for a answer……
                      Gonna get me a 42PFL9703D/10 tomorrow , so i got something to do
                      • tw2005
                        • Oct 2011
                        • 6458
                        well , you could always keep praticing removing the old buffer ic. took me a couple of goes to get one off clean.
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          • uk
                          #32
                          maybe tuesday when you get a answer as may bank holiday on monday may not be open.
                          • Moreno83
                            • Jun 2014
                            • 2008
                            • The Netherlands
                            #33
                            Hmm , will see what happens. Gonna repair the philips tv while i wait for a reply.
                            Replacing the chip , i will try that! If i don't get a answer or my money back then ill try to repair the board……
                            • tw2005
                              • Oct 2011
                              • 6458
                              What i meant was practice on the already stuffed board, lets hope you get the money back on the purchase.
                              • tw2005
                                • Oct 2011
                                • 6458
                                If it's SU Panasonic TNPA4784 SJ have 5,@ $17 USD, freight will push the price out a bit. Never had a problem with SJ as the parts were often from brand new damaged in transit Tvs.
                                • newtothis
                                  • Mar 2013
                                  • 1556
                                  • england
                                  #36
                                  What procedure did you use to lift the chip?
                                  Hot Air?
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    Hot Air?
                                    No, post #18 has a description. I've bitten the bullet and have a cheap rework station coming so i can try working on other things but getting that sealant off and I used acetone to help break it up but I found you needed to be liberal with it and constantly reapply since it's volatile and drys off fast but it did help.
                                    the chips are too expensive but I'd love to have a go at some buffer boards.
                                    • newtothis
                                      • Mar 2013
                                      • 1556
                                      • england
                                      #38
                                      I am gonna go chuck one on my IR station now and see what happens
                                      • newtothis
                                        • Mar 2013
                                        • 1556
                                        • england
                                        #39
                                        Took it off with the IR, Gave it enough bottom heat to melt the solder then gently used needle tweezers to get into the sealant and lift the chip out of it... Used plastic spatula to scrape the majority of the sealant off afterwards.... Used an old chisel tip at 330c to heat and break up the remainder. Finished of with MEK then IPA.
                                        • tw2005
                                          • Oct 2011
                                          • 6458
                                          you must be bored. It'd be nice to have all that gear but I did find using a solder iron tip broke it up. i think it's one of those jobs you have to practice and work out you're own way but it's good to share ideas.
                                          that's why once that board was stuffed of mine I kept trying
                                          • Andre Gilbert
                                            by Andre Gilbert
                                            11-20-2024, 08:52 PM
                                          • jm1234
                                            Panasonic plasma TX-P42ST50 - 6 blinks
                                            by jm1234
                                            anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                            It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                            I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                            I checked that board for any obvious faults...
                                            05-22-2024, 06:59 AM
                                          • riparo
                                            Panasonic Oled 55EZ950E, no picture, red led blinking every 4 sec
                                            by riparo
                                            Hi everyone, I have a Panasonic OLED TV model 55EZ950E, as soon as I turn it on I don't have any image the LED goes from green to red LED blinking every 4 sec, I found the service manual suggests checking OLED PANEL, PB BOARD, T-CON connectors but it seems like everything ok, I didn't find any burns under the pb board
                                            I attach a link to download the service manual, thank you for anyone who can help me
                                            https://tel-spb.ru/download/?brand=P...0E_LA73.rar​
                                            01-11-2024, 12:35 PM
                                          • Alicat
                                            Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                                            by Alicat
                                            Stopped by this site trying to fix my parents Panasonic Plasma TV.
                                            Model number is TH-50PZ85U
                                            Power comes on and the red power light stays on solid.
                                            Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                                            I also hear a few clicks.
                                            I also think my parents said there was a thunderstorm and the TV failed after that.
                                            Section 6 in the service manual talks about power and no screen,...
                                            10-30-2024, 10:09 AM
                                          • CrewmanRedShirt
                                            Looking for assistance troubleshooting a Panasonic TC-P65ZT60 with 3 LED Fast Blinks
                                            by CrewmanRedShirt
                                            Hello all,
                                            As the title states, I followed the troubleshooting guide located here: https://www.manualslib.com/manual/23...page=53#manual, which concluded the 'A' board needs to be replaced. Looking around the net and eBay, I see that there are repair services for the board (TNPH1043UE? Not sure if it is a 'UE' as the suffix grid does not appear marked). What additional troubleshooting can be performed to ensure 1) this board is the problem and 2) since there are repair services, what are they fixing on the board?) I expected 3.3V not to be available anywhere...
                                            07-13-2024, 11:02 AM
