Samsung 50PN4500 horizontal stipe
  • Ltank
    • Jun 2013
    • 776
    I had a Ysus problem. The original board Ysus EBR74825301 was burnt so got a replacement that has the 205 VDC. The original board shorted out the 205vdc. The new board has 205vdc but there is a wide horizontal section of good video but above and below it appears to have bad scan lines. Is it a bad
    Ysus or X board Control Board or Main Board. I have not had this symptom before. I will post a pic of the screen
  • Ltank
    • Jun 2013
    • 776
    Re: Samsung 50PN4500 horizontal stipe
    Pic of stripe
    • Ltank
      • Jun 2013
      • 776
      Sorry its a LG set. The Ysus and Buffer are a all in one board
      • mmartell
        • Oct 2013
        • 3189
        If the buffers are integrated into the YSUS then it looks like a faulty replacement.
        • Caleb
          Smokin IC's
          • Feb 2013
          • 645
          I had those lines show up on a panasonic I replaced the buffers on and mine was caused by misaligned ribbons into the buffer connnectors.
          Liberating magic smoke one part at a time
            It's very hard to line up those connectors properly. Check they are all perfectly seated as you will see this if they are not.
            Interesting that LG went for the combined Y-buffer/sus solution - they ain't done that before, even though Panny & Sammy have done it lots...
            • Ltank
              • Jun 2013
              • 776
              Thanks Guys. I reseated all the P Connectors on the Ysus. P 706 on bottom would not seat all the way. The flat panel cable would not go all the way in. I had to use a small too to expand the connectors so the flat cable would seat. I guess the flip lever was not all the way open when the removed the cable bending the fragile pins on the board not leaving enough room for the cable to seat properly.
                So it's fixed?
                • Ltank
                  • Jun 2013
                  • 776
                  Yes works fine
                    09-07-2024, 05:50 AM
                  • kotel studios
                    Samsung LC32HG70QQUXEN - vertical and horizontal stripes across the screen
                    by kotel studios
                    Just now my Samsung LC32HG70QQUXEN monitor gave up on me. On cold boots I get many vertical stripes going across the screen (see the attached picture). After it runs for 1-2 minutes those go away but there are horizontal stripes going across the whole screen no matter of the input and PCs I use. (couldn't take an picture of it since the image size goes to 20MB and the camera doesn't pick them up)
                    In a video about a 27" monitor with an similar issue the guy removes one resistor and supposedly the entire monitor goes back to life? For sure this fix is only temporary....
                    08-06-2025, 02:07 AM
                  • rstrube
                    ViewSonic Pf815 (branded as P225f) Horizontal Deflection Issues - Running out of Ideas
                    by rstrube
                    Note: apologies I initially posted this request for help in the wrong forum! I am reposting it here and will take down the original posting.
                    Hi Everyone,
                    I've been working on repairing this beautiful CRT monitor off and on for the past several months and I'm really at a loss for what might be causing the problem.
                    Unlike other common Horizontal Deflection issues which result in a steady vertical line, when I turn the monitor on, there is a pulsing (somewhat segmented) vertical line. I've attached a photo that shows the issue (difficult to capture without video)....
                    11-23-2025, 01:37 PM
                  • rstrube
                    by rstrube
                    Hi Everyone,
                    Unlike other common Horizontal Deflection issues which result in a steady vertical line, when I turn the monitor on, there is a pulsing (somewhat segmented) vertical line. I've attached a photo that shows the issue (difficult to capture without video). The monitor itself is branded as a P225f, but it turns out that it's actually a Pf815 that has an Add-On smallish PCB that expands it to support...
                    11-23-2025, 12:19 PM
                    09-06-2024, 11:40 PM
