Greetings! I picked up this tv with a 14-blink no power condition. After some research I decided to replace the SS board and rework the SN board, using the repair kit from ShopJimmy).
Now the TV powers on (good), both green LEDs are on for both the SN and SS boards (yay), but the image quality isn't right (bad). Picture attached. You'll see colored, snowy pixels. I ran the self test mode and everything it reported was 'OK'. I can run any test patterns and access the service mode if that will help. I had to adjust many parameters - like R-cut, B-cut, G-cut, R-drv, B-drv, G-drv, etc because at factory values the blue pop-up windows were completely washed out white. At least now I can read the text for testing purposes.
I've seen a few other threads having similar issues with Panasonic TV's and people suggested replacing and checking different components. I am electrically competent but don't have experience repairing TVs. I'm sure eventually I'll find shorts and replace the right component(s), but why reinvent the wheel when someone here probably knows right away where to look.
The shopjimmy SN repair kit included transistors Q401, Q402, Q421, Q422, D401, D421, and 4 resistors that sit next to the transistors. All have been replaced. I reworked a second time to be sure these components were down correctly.
What I'm asking for help with here:
1) What voltages should I check?
2) Which components should I check?
3) Why, in the service manual schematics, are components labeled Q16401 when on the PCB they are labeled Q401? What's with the extra 16?
4) I've seen reference to checking/replacing Q441, Q531, IC502, D481. Suggestions for sourcing these parts if I decide to replace?
Thanks - getting this tv over the bump to 1080p glory would make me most appreciative!
