Samsung 50" TV PS-50Q97HD wont turn on
  • YeOldeGinge
    • Nov 2014
    • 30
    • Telford and Wrekin
    Hi, People
    I have a Samsung 50" Plasma TV which will not power when I plug it in it makes a few clicking noises and the power light appears then when I click the power button it begins to flash 5 times then the light goes out as shown in the video.
    I have visually checked all the caps by eye and none look blown.
    If anyone could tell me what the problem and maybe how to fix it it would me much appreciated.
    I have a good general knowledge when it comes to electrical devices and have fixed TVs before but this TV has baffled me.
    TV's Details
    Make: Samsung
    Model: PS-50Q97HD
    Model Code: PS-50Q97HDX/XEU
    https://www.youtube.com/watch?v=Zf2dDgHRnLg
  • sordids999
    • May 2013
    • 2152
    Re: Samsung 50" TV PS-50Q97HD wont turn on
    Check to see if you have Vs + Va voltages on the power supply and also check for cold solder joints had a similar problem today
    • YeOldeGinge
      • Nov 2014
      • 30
      OK, would i have the TV plugged in while checking them and what setting on the multimeter should I use?
      • sordids999
        • May 2013
        • 2152
        Yes but be careful what your touching !
        on the panel should be a sticker giving you what the voltage readings Vs Va should be use the test points on the power supply marked up Vs Va set your meter to DC 600 volts use black lead on panel chassis then red lead to test
        • YeOldeGinge
          • Nov 2014
          • 30
          Ok ther is VA-TP and VS-TP are they the ones I should test
          • sordids999
            • May 2013
            • 2152
            yes
            • YeOldeGinge
              • Nov 2014
              • 30
              OK thanks i will get back to you in a second
              • YeOldeGinge
                • Nov 2014
                • 30
                Right for VS it was between 200V to 215V and I measured 206V and for VA it was between 60V to 66V and I measured 63V.
                what does that tell you ?
                • sordids999
                  • May 2013
                  • 2152
                  While your testing voltages you could also test Vsc and Ve but i would also check the under side of the power supply also for any damage etc but leave the tv powered off for at least 15 mins before handling the power supply
                  • YeOldeGinge
                    • Nov 2014
                    • 30
                    Right I have just measured VE at 94V and i have not been able to fine VSC are you able to send a more detailed picture? if not its fine a description will be as good
                    • sordids999
                      • May 2013
                      • 2152
                      Picture uploaded but i would also check for Q801 & Q802 on the underside of the power supply which if i remember its a common fault on these models
                      • sordids999
                        • May 2013
                        • 2152
                        https://www.badcaps.net/forum/showthread.php?t=39514 see here also
                        • YeOldeGinge
                          • Nov 2014
                          • 30
                          Right I have just measured the VSC and it starts at 170+V and slowly decreases voltage i am just waiting for the bored to discharge so that i can check the q801 and q802
                          • YeOldeGinge
                            • Nov 2014
                            • 30
                            Anyone have any idea what could be wrong with my TV? could really do with some help! :P
                            • Alastair E
                              Chief Womble
                              • Mar 2013
                              • 1963
                              • U.K.
                              Is there a tiny green LED lit on the Y-SUS board, (in bottom right hand part) when the set is turned on....?
                              TELEFIX
                              • YeOldeGinge
                                • Nov 2014
                                • 30
                                Is this the light you are talking about?
                                • YeOldeGinge
                                  • Nov 2014
                                  • 30
                                  Help me!
                                    LED lit = fault on Y-main
                                    • YeOldeGinge
                                      • Nov 2014
                                      • 30
                                      What do you think the problem might be?
                                      • Alastair E
                                        Chief Womble
                                        • Mar 2013
                                        • 1963
                                        • U.K.
                                        The Y-SUS is in 'Protection-Mode' hence that LED.
                                        The protection circuit monitors three things. The ERC circuit, the VSCC and summit else that I cant recall...
                                        I have one exactly the same--and same fault. Spent probably 50 or 60 hours on it, and no progress. Many parts replaced, no obvious faults. I'm suspecting one of the ERC or other MOSFETS/IGBT's is O/C....
                                        This fault (If the same fault as mine--and Ive seen two Y-SUS with this fault)--Unless you stumble on it is NO quickie.
                                        Replacement Y-SUS (05120A) are expensive and in short supply.
                                        First off for yours--Check for shorts on all the silicon power-devices of the Y-SUS, also check the small fuses on the supplies to the DC/DC converter stage--Thats the part the protection circuit shuts down via a quad-comparator....
                                        TELEFIX
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
