Samsung ps50q97hd
  • sordids999
    • May 2013
    • 2152
    • uk
    Samsung ps50q97hd
    hello
    just got this tv it seems the psu is clicking on powering up ive tried disconnecting the ysus/xsus but seems to be the same so im gathering its the psu ?
    any help appreciated
    Re: Samsung ps50q97hd
    Check all the fuses on the PSU - a common fault on these is shorted FETs on the Vs or Va/15V tract; easily fixed.
    • sordids999
      • May 2013
      • 2152
      • uk
      it seems on further testing ive noticed on the underside of the psu some blown components
        Yep, looks like you have the common fault. It's not too hard to fix, and those component values are known from the schematic. I bet you will find adjacent transistors shorted.
        • sordids999
          • May 2013
          • 2152
          • uk
          yes tom as per picture there shorted alright
            Yep ! Pretty explosive failure there...
            QX801,QX802 = FQFP11N50CF
            DX803,DX804 = BAR43C (the "C" very important)
            RX833,RX832,RX803,RX802 = 20R 1206
            RX804,RX805 = 10k 1206
            F803 = 250V 8A time-delay fuse
            Power up initially with lightbulb in place of F803 = if bulb flashes install fuse and test TV.
            • PowerAmpFreak
              • 982
              • Sweden
              From pictures it's easily seen that reason for blowing is poor solderjoints on QX801 and 802.
              Actually, I have only had one blowing up and numerous fixed only by doing new soldering.¨
              Those PSU's are quite reliable.
              • sordids999
                • May 2013
                • 2152
                • uk
                http://www.ebay.co.uk/itm/CLICKING-1...item416e8f262a
                would that work guys ?
                and never really changed the small components before but i would say my soldering skills are pretty good so any good tips on changing these properly ?
                  Looks good.
                  The small SMDs are easy enough - just flood each side with solder to lift off.
                  Look up SMD removal on youtube.
                  • sordids999
                    • May 2013
                    • 2152
                    • uk
                    ok thanks hopefully update soon
                    • sordids999
                      • May 2013
                      • 2152
                      • uk
                      im guessing you mean incase something else blew the psu ? ive also checked fuses on ysus and xsus seems ok
                      but fingers crossed ive ordered the parts and ill update when i have recieved the parts
                      now time to test my skills on a old board before they arrive
                        Mainly to avoid blowing up new parts - It is very rare for other parts of the TV to damage the PSU.
                        • PowerAmpFreak
                          • 982
                          • Sweden
                          As I said, failure is 99.9% because of bad soldering. This made the bridge crossconduct and blow.
                          • sordids999
                            • May 2013
                            • 2152
                            • uk
                            hello i connected the parts but the test bulb comes on fine but switches of then comes on again with the relay clicking on the psu,ive tried disconnecting the ysus/xsus but its still the same ?
                              That is normal for this PSU, all you care about for now is that it does not light up continuously meaning there are no shorts. You will have to put a fuse in and test it.
                              • sordids999
                                • May 2013
                                • 2152
                                • uk
                                ok thanks its working VS is 205 VA is 62.5 but the tv wont turn on no picture sound etc
                                • sordids999
                                  • May 2013
                                  • 2152
                                  • uk
                                  control board light is coming on and staying consistent but it seems the side button and samsung main power switch on the front is not working possible main board failure ?
                                    Is there a light glowing on the Y-main?
                                    • sordids999
                                      • May 2013
                                      • 2152
                                      • uk
                                      it seemed the ribbon going from the ysus to control board was removed and not put back properly from the previous guy who owned the tv all working at the moment but time for testing
                                      thanks guys for your help
                                      • sordids999
                                        • May 2013
                                        • 2152
                                        • uk
                                        Does anyone know the length and size of the screws to mount the stand i never had any with the set
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
