need part for ymain for samsung pn42a450p1dzxa
  • TechOp
    • Oct 2013
    • 21
    Hey gang,
    After a week burnin had this TV come back with no picture but sound. I headed straight to the Y main board and voltage on the buffer was only 29v. Started checking the board visually and found what looks like a blown zener Diode. Wondering if any one has a schematic or knows the part number on that diode for a cross refer?
    ymain p/n: Lj41-05075a
    ZD5003
    sigpic
    Anything can be fixed with enough TIME and enough MONEY
    Re: need part for ymain for samsung pn42a450p1dzxa
    Looks ok to me. Zeners usually fail short or open. If that part has died in that location, it is likely Q5004 nearby has failed causing fault.
    I'd look at bad Y-buffer causing this, does Vsc/Vsch come back if Y-buffer out?
    Also check if control board is shutting down due to fault detect (will cause Vsc/Vsch to drop out) - can be due to X or Y-main fault...
    • TechOp
      • Oct 2013
      • 21
      Looks ok??? interesting....... I will check after my parts run to storage.
      sigpic
      • captainKKK
        Part identification for Samsung UN50F6300
        by captainKKK
        I need to replace the pictured small (3x2 mm?) Samsung LED strip component. I traced it the entire length of the first section of the strip. I assume it provides the positive voltage for the 2nd, shorter, plugged part of the strip. It's the one labeled 24V and scribed with 4E. AJ. Ideas for replacements, thank you.
        10-25-2024, 04:18 PM
      • baxmax
        alternative diode to Samsung TV 55 mb
        by baxmax
        Hi, Recently my Samsung 4K QE55Q60AAUXXH just suddenly stopped working_ there is no any sign of life - no red light or anything..and think, after diagnostic, it is diode DM863c SF28e PK33 siyu or one of these four. Is there any alternative I can replace with since it is hard to find it in my country and to order outside is quite difficult. thank you...
        10-21-2024, 07:35 AM
        Samsung UN58MU6070FXZA LED TV Part List
        Samsung UN58MU6070FXZA LED TV Part List...
        10-12-2024, 11:59 AM
      • edugimeno
        Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
        by edugimeno
        Hi There!
        I'm trying to help my friend who owns a restaurant be just bought.
        He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
        It's stuck using, I guess, the 2 sided tape that comes with the strip
        The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
        09-05-2024, 09:34 AM
      • G-Sting
        iPad Pro A1876 SHORT Part Identify Help Needed
        by G-Sting
        So My iPad was not charging and booting up . i went to a local technician and he checked with thermal and this Part marked in 1st Photo is Short.
        So then i went on to boardview and downloaded the schematics and identified this part in 2nd Photo. Now i am confused what exactly is the part called ? where should i get this from ?
        i contacted my technician and he sent me his BoardVIew screenshot in 3rd Photo. In his Boardview the part is called X2826.... Something
        SO My main concern is what part should i order what should i search the name for ?
        on Ipad...
        05-15-2025, 09:30 AM
