SAMSUNG PLASMA 50INCH PS50Q7HD No Picture
  • Tobinuk
    • Mar 2015
    • 9
    • England
    (Sorry for long detailed post)
    I hope someone could help me out? I have a SAMSUNG PLASMA 50INCH PS50Q7HD which I bought secondhand 4-5 weeks ago. The t.v was a spares & repairs job (£40) and I understood at the time it had no picture... But it had sound. I purely bought it as I have fixed a few smaller tvs in the past.
    I did a bit of research before buying it and read on the net it was probably the Ymain & buffer boards faulty and a quick look on ebay prompted me into getting the tv as spares were available. On getting the tv home (after buying it) I decided to switch tv on and within minutes there was a small pop and a little smoke came from the top right of the set.
    After letting the tv power down for an hour I decided to take the back cover off and have a look...I quickly discovered that the Ymain board had a few blown diodes which indicated a problem.
    I also read that as a certain section of the Ymain diodes had blown, it was likely the bottom buffer caused the problem......... It seemed an easy fix!!!!
    I ordered a new Ymain board and a "Pair" of buffers from Cradeal.co.uk which arrived today! I have now fitted them to TV. Unfortunately I still only have sound and NO picture........ which was the original problem!
    I really am back to square one!?!
    The set now stays on with the sound coming through nice and clear!
    There is no image, no flecks, even if you press menu... there is nothing!
    I had checked all VS and other outputs and they all appear to be fine. I have seen other test on Youtube and my VS etc are within the 2v range.
    The TV cost me £100+ and the moment Any advice would really be appreciated, as this is the second package from cradeal after they sent the wrong parts last time??!!
    I could ask Cradeal for a refund on the lot if the Ymain and buffers should have fixed the problem, as they could be faulty themselves I suppose!
    I even tested my old buffers before replacing and I was never convinced they were faulty as I could not get them to fail in Continuity test. I purely replaced all 3 boards as Cradeal would cover the lot in 60 day warranty and following other people advice. To me it made sense to buy as a package.
    Like I said before I could go for a refund, but I prefer a fix!
    I sure you guys understand
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: SAMSUNG PLASMA 50INCH PS50Q7HD No Picture
    Hmm--I wonder.....
    On the Y-SUS board in your set--Is there a tiny green led illuminated when the set is on ...?
    Not sure if your exact set uses the same y-sus as my trouble-making heap of crap, but there shouldnt be any led lit on the y-sus if all is good....
    --The led in my case means a protection circuit has activated....
    TELEFIX
    • Tobinuk
      • Mar 2015
      • 9
      • England
      Thank you for the interest Alastair.
      The Y board does not have any led on.....
      Although there was a green led on a board underneath the scart/audio board?!
      I only noticed it tonight as I happened to move the TV before I put it away. Is this other board (underneath scart/hdmi/audio board) the control board?
      Could this cause no picture?
      As I have said before the voltages all appear to be ok, wondering if it Xmain??
      Any input appreciated
      • Alastair E
        Chief Womble
        • Mar 2013
        • 1963
        • U.K.
        What voltages have you tested...?
        VSC...? etc....
        TELEFIX
          See if the control/logic board - underneath the main A/V board - has a little light on it flashing.
          No glow from the screen at all? Any buzzing from the Y-main/X-main?
          • Tobinuk
            • Mar 2015
            • 9
            • England
            I checked all the voltages to and from powerboard and compared them to the panel sticker inside TV. The voltages were as stated on panel sticker, although there was a marginal 2v under.
            I also checked the voltage coming out of the powerboard to Ymain etc and those vsc voltage etc were also fine....... as above?!
            Hmmmm indead!
            (TV Panel back on and away until morning more testing tommorow)
            • Tobinuk
              • Mar 2015
              • 9
              • England
              Thanks for the replies everyone!
              I have posted a video on YouTube..... Which took me a while to get round too
              As an update I have retested all Va, VSC,Vs,Ve & Vset voltages and all of them are spot on. I noted in my video below that I spotted a Green LED which was on Solid LED2000 & another LED which Flashes LED2002.
              As it was on the Contolboard I thought it was Suspicious at first!
              I don`t think LED 2000 is anything to worry about now! Correct me if im wrong??!!
              IMPORTANT!!!!
              When the TV (Ymain) first went pop I researched online and took others recommendations to replace the Y buffers and Ymain as a package. After fitting the set (hence my thread) I still have the same problem!
              Seeing as my original buffers tested fine out fine a few weeks ago I took the plunge since filming my video too fit my old buffers back to TV, leaving the new ordered buffers in the bag...... I switch the TV and still get sound, no picture and the TVs been on for over 1hr+ with no issues??!!
              The LED2000 is till on solid and the LED2002 is still flashing, even with my old buffers fitted to the TV or the New buffers..... STUMPED!!
              Step back Spielberg..... Let the camera roll!!
              youtu.be/UFLx1S6-3Hs
              • sordids999
                • May 2013
                • 2161
                your video is set to private
                • Tobinuk
                  • Mar 2015
                  • 9
                  • England
                  WOW.... Did that take forever to upload!
                  Don`t think it was set to private. I premature-posted on forum before video uploaded...... Please try again
                    Green flashing LED indicates control board is running and working, and it is trying to sustain the panel (trying to make it light up) - these older panels don't have any feedback, so if something fails the control board will still try its best to make the panel light up. A slow LED flash (2-5 blink, 2sec on 5sec off) on newer Samsung panels is a protection fault. But again, doesn't apply to your set.
                    In a pitch black room, do you get any glow from the screen with your new boards?
                    You can try checking the various heatsinks on the Y-main and X-main and see how the temperature varies. Use the back of your hand. Do not attempt this on the power board.
                    • Tobinuk
                      • Mar 2015
                      • 9
                      • England
                      Hi Tom66,
                      The TV does not have any glow whatsoever. I checked yesterday evening by wrapping our curtains, over my head too see if there were any flecks etc....
                      ...... But No Go.......Or should i say Glow
                      And so it continues.........
                      • Tobinuk
                        • Mar 2015
                        • 9
                        • England
                        I had the TV on for another hour today as I thought I would see how the heatsinks felt. The Ymain board felt cool to touch and the Xmain was mildly warm. I was able to keep my hand on it put it that way!
                        I am open to more suggestions....... Thanks again for your time!
                          Are all fuses including the small SMD/soldered ones OK?
                          • Tobinuk
                            • Mar 2015
                            • 9
                            • England
                            Hi all, back again.
                            Been away as I have had spinal surgery which has taken weeks to recover...... Now back to RL and this bleeding TV!
                            I have checked the fuses as suggested and all seem well. More suggestions are welcome. I am still a little concerned that LED 2000 is permanently on, while 2002 flashes (like an indicator) on the control/logic board.
                            Also the X-main syncs are definitely hotter than the Y-main as I have had the TV on for over an hour today listening to the sound.
                            Could the Xmain be the culprit or normal?
                            Cheers again for your dedication
                            • ArMaaN376
                              Samsung PS51E550 Plasma TV
                              by ArMaaN376
                              I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
                              Opened TV cover & observed foll
                              a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
                              b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
                              c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
                              How to confirm Y -Buffer board...
                              06-19-2024, 04:05 AM
                            • jm1234
                              Panasonic plasma TX-P42ST50 - 6 blinks
                              by jm1234
                              anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                              It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                              I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                              I checked that board for any obvious faults...
                              05-22-2024, 06:59 AM
                            • KYBOSH
                              Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                              by KYBOSH
                              Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                              No picture but you hear the TV static (white noise) playing loud and clear.
                              The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                              But it seems they didn't get too far and just left it.
                              When I first took a look I was amazed at how pristine the inside looked.
                              Its as if the TV had been in a time capsule.
                              Caps looked like they were just pulled off the self.
                              Copper coils had no sign of corrosion on...
                              02-01-2023, 11:10 PM
                            • alltvrepairs
                              Plasma Samsung PS-50C96HD Main board BN94-01223C switches off supply after few seconds
                              by alltvrepairs
                              I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
                              I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
                              Any one met this problem in the past?...
                              10-08-2025, 07:34 AM
                            • chazh
                              LG 60PS11-UA 60-inch 1080p Plasma TV-service lit & video help needed
                              by chazh
                              This is my first posting, so forgive me everyone in advance if I made mistake(s) in my posting.
                              I know there have been much about this plama tv already and I have read through most what I could find. However; I still have not come across any service lit/schematics for this tv. I even looked for the 50PS11 which would be basically relevant other than display size. Anyone know to find the documentation would greatly be appreciated.
                              The set that I have has issues with lower third of screen being dimmer than the above portion. From my past experiences with tube, solid state,...
                              09-01-2025, 08:56 PM
