Please help LG TV Not Programmed Error
  • sureshbobby
    • Mar 2015
    • 137
    • India
    Dear Friends
    Please help am getting Not programmed error, in LG LCD 22 inch tv, i have done reset, upgraded firmware, and when am doing autotune its showing no channels.
    Checked antenna with other tv working fine
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: Please help LG TV Not Programmed Error
    It would be the Tuner itself, the DVB Processor or something related to those....
    I would recommend replacing the complete Mainboard--Or use the set as-is, with a DVB/SKY/Satellite box/PVR....
    TELEFIX
    • Sus256
      HISENSE 65E7KQ PRO - no boot
      by Sus256
      Hi all!
      HISENSE 65E7KQ PRO
      RSAG7.820.13512 - chassis
      MT9618BAATAB - cpu
      RSAG7.820.12059 - power
      HD650Y3U77 - panel
      KLM8G1GETF - emmc
      Replaced emmc.
      Terminal log
      UART
      AC_ON
      E-B
      FDE enabled
      06-01-2025, 02:11 AM
    • sushilachuthan
      APC UPS error P13
      by sushilachuthan
      one of our new (only 4 year old) 1KVA APC UPS stop working and through error P13 contact customer support.
      the equipment is out of warranty , upon investigation, we found the inverter board has the fault on the output hybrid relay circuit.
      The inverter output relay is parallel by SCR/Triac to enhance the relay performance or other means.
      We replaced the SCR with new device,, but the device is not power on as expected.
      Further research on the issue found that, the error P13 (event ID 107) is latched on the UPS nvram/MCU and need to clear/reset using a service procedure....
      09-26-2025, 09:00 AM
    • Superbee_dad
      Sharp 80” long short flash backlight error - Help
      by Superbee_dad
      Hello Sharp TV experts
      Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
      > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
      > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
      01-24-2025, 11:51 PM
    • Curtissimo
      HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
      by Curtissimo
      Hi everyone.
      I have a HP Elitebook 850 G8.
      Serial: 5CG2324XM0
      ProdID 6L8D5EC#ABA
      It has a Winbond W25Q256JVEN Chip.
      I need to remove BIOS Password.
      I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
      Attached my dump.
      I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
      I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
      What I did:...
      08-26-2025, 04:42 AM
    • Maalobs
      Philips 60PFL8708S/12 - QFU1.2E LA - Error code 53
      by Maalobs
      I have a 2014 vintage Philips 60PFL8708S/12 that suddenly died in the middle of the kids watching a show.
      The relevant service manual for the chassis is available here.
      The TV no longer powers on, and leaving it powered on for a few minutes results in the layer-1 error with 2 blinks.
      When I short the SDM to ground I get the layer-2 error code 53.
      The inside of the TV has no damaged components and no swollen capacitors.
      In SDM-mode when all the power rails are left on despite entering the protection mode, I tracked down and measured...
      04-02-2019, 01:15 PM
