LC46XD1E repair
  • marco1000
    • Mar 2015
    • 6
    • Rwanda
    LC46XD1E repair
    Hello am trying to fix this sharp LC46XD1E it have the problem of motherboard of PSC10189dm PKG1 which does not release the current to the screen and the lights does not light up. Am not able to upload the picture because am new on this forum but if you know something plz reply thank you.
  • Dang
    • Aug 2013
    • 440
    Re: LC46XD1E repair
    If I understand Sharp Tvs correctly, if there is an issue which forces it in to a power protect mode, turning it on and off 5 times or more will throw it in to a mode where the back light will not turn on, I had this with an old Sharp LCD and only entering the service menu would resolve it, of course I could not see this so the correct presses on the remote were needed. I'm sure if your just a little more patient some one will give you more clarity.
    • marco1000
      • Mar 2015
      • 6
      • Rwanda
      Re: LC46XD1E repair
      The problem is that the power supply PSC 10189DM PKG1 does not release the current to the screen!
      • Alastair E
        Chief Womble
        • Mar 2013
        • 1963
        • U.K.
        Re: LC46XD1E repair
        With set unplugged, Press Input and Ch - Hold both buttons and plug in keep holding buttons for a few seconds.
        Set should fire up in Eng mode....
        TELEFIX
        • marco1000
          • Mar 2015
          • 6
          • Rwanda
          Re: LC46XD1E repair
          When you connect the circuit the relay will pup without stooping and then the current Which goes to the red of the screen will not start, is there any replacement tools needed for this board so that the current goes to the screen?
            Re: LC46XD1E repair
            Did you try Alastair's suggestion? Note on some Sharp sets you need to unplug them, hold the buttons then plug them in; others, you need to turn them off using the "soft off" button (which should make the standby light go off), hold the buttons, then press the "soft off" button again (to turn it on into standby) then press the power button to turn it on. You need 3 hands...!
            • marco1000
              • Mar 2015
              • 6
              • Rwanda
              Re: LC46XD1E repair
              Yes I've tried Alastair's solution but unfortunately the sharp does not turn up. on check the attached picture that i took, I think the problem is with the board if you check the picture above that i have uploaded you will see the area with the red lines are the one having problems
              • Alastair E
                Chief Womble
                • Mar 2013
                • 1963
                • U.K.
                Re: LC46XD1E repair
                There could be many reasons why this is not working.
                You need to do things methodically. Check that PSU board where the leads go to the Mainboard.
                One or two of those leads will be marked, 5V
                Is that 5V present?
                The Mainboard makes the PSU Turn On,--But only if the ever present 5V is actually supplied to the Mainboard in the first place!
                I can make NO sense of your picture or the 82V you speak of.....
                TELEFIX
                • marco1000
                  • Mar 2015
                  • 6
                  • Rwanda
                  Re: LC46XD1E repair
                  Yes the 5 volts are present but the problem is with those 2 capacitor marked with "red circles on the picture" 1 capacitor have 100v but when they are active they releasing only 82v!
                    Re: LC46XD1E repair
                    That is only a voltage rating that the component is designed to withstand. Theyc can use put less than 100V across them.
                    • roy.zhero
                      Sharp LC50LE752E no picture and backlight, indicator light is lit
                      by roy.zhero
                      I acquired a free 50” TV. IT is a Sharp LC50LE752E. It does not show a picture and has no backlight, although the indicator light turns blue meaning it has turned on.
                      When power is plugged in, the indicator light will turn on blue, the backlight stays off and nothing is visible, even with a flashlight. When pressing the touch buttons on the tv nothing happens. When pressing buttons on the remote control the indicator light will blink indicating the IRsignal was received, but nothing happens.
                      When I hold the force-on-combination it will turn on. It then shows a perfect...
                      09-20-2020, 01:57 PM
                      Lithonia Lighting versus Light of America Compact Fluorescent product quality
                      by sam_sam_sam
                      I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
                      I also have back when Light of America had these light bulbs available for yard lights
                      The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
                      While the Lithonia lighting fixture has all most certain bulb failure
                      So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
                      I have only had this light fixture for not more than a year if it...
                      07-02-2023, 03:45 PM
                      LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
                      This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                      09-07-2024, 03:40 AM
                      LG Gram Ultra-Light Laptop Notebook Specification for Upgrade or Repair
                      This specification for the LG Gram Ultra-Light Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Light Laptop boardview and Ultra-Light Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                      09-06-2024, 09:10 PM
                      09-06-2024, 08:40 PM
