Panasonic tc-p55vt30 - 7 blinks. Now what?
  • B-Rad
    • Mar 2015
    • 5
    Hello all. I realize there have been posts about this issue already, but I couldn't find exactly what I was looking for.
    My Panasonic 55' plasma tv shut off the other night and now it won't turn on. Instead the red light blinks seven times over and over. I understand that this is most likely a bad sc board, but I want to be certain before I order a new one. I also want to know if the other two boards are bad, so I know whether to order those as well. That's why I started this thread. Any help will be greatly appreciated.
    I took the back cover off and inspected the three boards and I don't see any burn marks or anything else abnormal, but I don't know exactly what to look for. None of the screws were very loose, but I made sure every single screw Is tight. I don't recall hearing any buzzing before the tv shut off either. The service manual states that I need to use an SC jig to connect to the SC50 connector on the sc board. However, I do not have an SC jig, so my questions here are;
    is there another way to determine if the sc board is indeed bad, if the problem is with one of the other boards, or if it's something entirely different? Can the 7 blinks only be the result of a bad sc board? If someone can please tell me how I can figure out the exact issue, I will be most grateful. Then I can order the parts that I need and hopefully be able to watch some exciting college basketball this weekend without having to spend too much more money on this tv, considering I paid $2200 for it brand new only three years ago.
    I called Panasonic and of course they refused to pay for any of the repairs and even had the nerve to deny that this is a manufacturers defect or even a known issue. I was so upset that I had to apologize to my children for the language I used and for yelling so loud. Hopefully I can get it fixed soon so we can all enjoy watching tv again...
    I just remembered that my tv was running very hot lately and I read somewhere that having the contrast set too high could cause that. Now that I think about it, I did have my contrast set really high. Could this cause the 7 blinks? Is there a way to reset the contrast and get my tv to turn on again?
  • Shinju
    • Mar 2014
    • 1239
    Re: Panasonic tc-p55vt30 - 7 blinks. Now what?
    https://www.badcaps.net/forum/showthread.php?t=44315
    • B-Rad
      • Mar 2015
      • 5
      Thank you for the fast response Shinju. I did read your thread before and I saw that you jumped the SC50 pin to determine your sc board was bad. I don't have the SC jig tool. Is there another way to jumper that SC50 pin? I pulled a jumper off of a computer motherboard, but it doesn't fit.
      • Alastair E
        Chief Womble
        • Mar 2013
        • 1963
        • U.K.
        Typical Corporate denial of a well known issue!
        SC boards of more recent Panasonics are known to fail--There's even an upgrade 'screw-kit' for the sets!
        --The original screws lose pressure on the mounts, the board earth return points then become intermittent, start to arc and the pulsing and arcing causes destruction of the IGBT devices on the board and giving the fault you have...
        Failing the screw issue, the heat those devices run at is surely to reduce their expected life-span....
        Average time of failure is around 4 thousand hours use IME,--WAY below their advertised 50,000 hours of Panel life!
        So--Yes, It IS a manufacturer error--which they know bloody well, but admitting it would cause a huge inrush of claims and replacement SC/SN boards--They cant afford at the moment, their shareholders would go tits up!!
        TELEFIX
        • Alastair E
          Chief Womble
          • Mar 2013
          • 1963
          • U.K.
          SC 50 'jig' is merely a shorted plug. You can use a jumper from a hard-drive or even (What I use....) a small croc-clip,--just make sure its not touching anything else.
          Just short the two pins of SC50 and there you go--ready to test.
          TELEFIX
          • B-Rad
            • Mar 2015
            • 5
            Ok I finally got a chance to disconnect the three connectors between the SC board and the SU/SD boards. I also jumpered SC50. When I plugged the tv back in and hit the power button, the same exact thing happened - a solid red light for 2 or 3 seconds and then 7 blinking red lights over and over. What does this tell us? Should I do some further testing? Thank you everyone for your help.
            • Shinju
              • Mar 2014
              • 1239
              Sc board is dead, Google moduslink tv parts and in their search box put in the SC board part number including the suffix at the end, once you find it click the return/repair option buy it, get the packing instructions, pack the SC board for safe transit, wait for the repair to complete, get the part/parts and installed them (make sure to get the new updated screws from shopjimmy THIS IS A MUST DO or you will blow your newly repaired SC board.
              Shopjimmy sells the screws under the TC-P55GT30 model but they use the same boards as the VT30 and I am using them in mine. Replace them all for the SC/SS SD/SU and the 2 for the SS sub board attached to the SS.
              If I was you I would select the package deal they offer for 275.00 and send your SD/SU Buffers with the SC board too chances are when the SC short it could have took out or damaged your buffers.
              • B-Rad
                • Mar 2015
                • 5
                Thanks Shinju. How long did it take for you to get your board back? So there's no way to test the SD and SU boards myself? Also, I've seen SC board repair kits for sale. Is it really difficult to repair the SC board? I'd rather do it myself so that I can save some money and get it fixed faster, but if it's too difficult then I'll go your route.
                • Shinju
                  • Mar 2014
                  • 1239
                  Are you good at difficult SMD soldiering and have a hot plate or good heat gun? I have seen guys destroy their SC boards trying to DIY repair these.
                  Plus with MosusLink you will know it's a solid repair and you have a warranty.
                  • MEMOFER
                    • Sep 2013
                    • usa
                    Hi, my first post here, shinju do you have experience with ModusLink, are they reliable?, I have the same plasma model and my SU board is dead, it has a short, my SC board is now good, after I replaced 3 shorted transistors and the SD seems good when I do resistance check.
                    I can not find any SU board anywhere on the net for a reasonable price. sorry to intrude on this post.
                    • Andre Gilbert
                      by Andre Gilbert
                      11-20-2024, 08:52 PM
                    • Biruslapio
                      Panasonic P58V11B 8 and 12 blinks error "fix"
                      by Biruslapio
                      Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                      Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                      04-13-2021, 07:13 AM
                    • jm1234
                      Panasonic plasma TX-P42ST50 - 6 blinks
                      by jm1234
                      anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                      It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                      I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                      I checked that board for any obvious faults...
                      05-22-2024, 06:59 AM
                    • Alicat
                      Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                      by Alicat
                      Stopped by this site trying to fix my parents Panasonic Plasma TV.
                      Model number is TH-50PZ85U
                      Power comes on and the red power light stays on solid.
                      Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                      I also hear a few clicks.
                      I also think my parents said there was a thunderstorm and the TV failed after that.
                      Section 6 in the service manual talks about power and no screen,...
                      10-30-2024, 10:09 AM
                    • CrewmanRedShirt
                      Looking for assistance troubleshooting a Panasonic TC-P65ZT60 with 3 LED Fast Blinks
                      by CrewmanRedShirt
                      Hello all,
                      As the title states, I followed the troubleshooting guide located here: https://www.manualslib.com/manual/23...page=53#manual, which concluded the 'A' board needs to be replaced. Looking around the net and eBay, I see that there are repair services for the board (TNPH1043UE? Not sure if it is a 'UE' as the suffix grid does not appear marked). What additional troubleshooting can be performed to ensure 1) this board is the problem and 2) since there are repair services, what are they fixing on the board?) I expected 3.3V not to be available anywhere...
                      07-13-2024, 11:02 AM
