Re: Samsung UN60D6000SF LED TV Sound but blue screen
Hmmm. I may just try it. I'venever opened a panel before. What would I be looking for? Type of Damage?
Still, it would be worth opening up the panel just to check.
9 times out of 10 it's not fixable but we've seen some success stories where water damage can be fixed.
And one case of an easy fix, with a shorted MLCC.
If it's scrap anyway... may as well try.Last edited by tom66; 03-15-2015, 02:37 PM.Leave a comment:
Awe shucks! Not the news I was hoping for. Thanks for your help guys. I really appreciate your time, and sharing of knowledge.Leave a comment:
No, this indictes that the LCD panel is shorted on one side. Unfortunately in most cases this will not be repairable. Sorry.
The moisture there is just left over from the thermal SIL pad... nothing to worry about.Leave a comment:
Try disconnecting the tft ribbons connecting the t-con to to the panel, try one side power it on with a source to see if you get a picture on the side that is still connected to the t-con.
I had a UN46 doing what yours is and it ended up being a t-con failure. But make sure your panel doesn't have moisture damage on the tft board connecting to the panel itself or you might blow another t-con if there is damage.
Also, I noticed a wet substance on the big black processor in the center of the T-Con board, after the above mentioned test. What does that moisture mean? See picLast edited by TubeJunkie; 03-15-2015, 12:09 PM.Leave a comment:
I had a UN46 doing what yours is and it ended up being a t-con failure. But make sure your panel doesn't have moisture damage on the tft board connecting to the panel itself or you might blow another t-con if there is damage.Leave a comment:
I'd say T-con or panel failure.Leave a comment:
It's a faint blue that kinda gets lighter and darker. Much like this guys video
http://youtu.be/s2hLKzdyDWULeave a comment:
blue screen - is it only a faint dark blue or a full on, blue sort of like "no signal" screen old VCRs/TVs had?Leave a comment:
Hi. I have a Samsung UN60D6000SF LED TV. Has good Sound but blue screen. The red power light flashes when starting up. Which normally means power supply problem? Anyone have any advice or experience with this? Look how skinny the power supply caps are! Could I have a bad T-con board? I'd love to have a schematic on this model. I took some voltage readings:
Samsung 60" LCD
Voltage readings:
From PS board to main board:
1. 5.33v
2. 5.33v
3. 0v
4. 17.1v
5. 12.8v
6. 12.8v
7. 0v
8. 3.28v
9. 3.28v
10. 3.28v
_____________________Tags: None
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by mar1inHi everyone,
I've got this Samsung here that would be stuck in a boot loop.
After opening up and doing the tape block method, I was able to get it to turn on and play sound from the HDMI input, but with a blue screen.
Does that mean there is another combination of pins that I need to block in order to get a picture, or is there something more serious, faulty mainboard or faulty panel?
Thanks in advance -
by jchangHi all
I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
Symptom:
No picture no sound.
When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
No sound at all.
What I tried:
1. I tried unplugging the left or right ribbon... -
by IerwinHello everyone,
Anyway I still fully expect that there has been something seriously damaged... -
so i took out one of my spare gigabyte ep35-ds3r mobos from storage for use to do some cpu, ram and video card testing of stuff i bought from ebay and got for free from momaka. he bought 50 e8400 cpus for cheap from ebay some years ago and i decided to help him relieve him of some of his supply since he had waaaay too many!!
what did we say about hoarding too much stuff and depriving others of them?! *cough* socialism *cough* lol!
i had to blow some dust off the board and heatsinks with the datavac as i didnt clean it up before putting it in storage. after finishing...-
- Loading...
