Panasonic TX-P50GT30B screen problems
  • marekk
    • Mar 2013
    • 36
    After repair of the SC board I noticed very thin part of the screen at the top which shows blue sparkles. the area where this sparkles does appear is around 10 pixel lines tick and runs through most of the screen length. On top of that there is quite significant screen burn on the right side of the screen.
    Is that repairable?
    I would really appreciate any advice with this problem.
    Best regards
    Mark
  • marekk
    • Mar 2013
    • 36
    Re: Panasonic TX-P50GT30B screen problems
    Ok, blue sparkles I have solved partialy by dropping the VSUS to 209V, I hope it's not too low, stil this part of the screen is sligtly brighter than rest.
    • tw2005
      • Oct 2011
      • 6458
      what's vsus set to in serv menu, hi or lo? from memory 204V lo, 209 hi. I think we've seen this before, generally the Vsus is factory set and sealed at the P board and then the A board controls it from there
      • marekk
        • Mar 2013
        • 36
        VSUS in service mode is LOW, I couldn't even change it to HIGH
        • tw2005
          • Oct 2011
          • 6458
          you can, just need to read the service manual procedure on how to do it.
          • jean luc ferre
            laptop hp g72 b52sf screen problems
            by jean luc ferre
            on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
            the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
            i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
            i don't understand the reasons of the white stripe at the bottom of the screen below the task...
            06-07-2025, 03:27 PM
          • Ryan.man
            by Ryan.man
            02-04-2025, 12:23 PM
          • Chrissygizmo
            Panasonic TX-48CX350B backlights but white screen , blank screen
            by Chrissygizmo
            Hi all, I’ve got a problem I hope someone can help me fixi.
            I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
            01-11-2025, 03:18 PM
          • Alicat
            Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
            by Alicat
            Stopped by this site trying to fix my parents Panasonic Plasma TV.
            Model number is TH-50PZ85U
            Power comes on and the red power light stays on solid.
            Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
            I also hear a few clicks.
            I also think my parents said there was a thunderstorm and the TV failed after that.
            Section 6 in the service manual talks about power and no screen,...
            10-30-2024, 10:09 AM
          • reformatt
            by reformatt
            07-31-2025, 08:37 PM
