Hitachi 42HDT79 Plasma TV "Dancing" Pixels Issue
  • darkNiGHTS0
    • Mar 2015
    • 6
    I picked up a Hitachi 42HDT79 sitting by the curb today and plugged in it. So far everything works great, except for a "dancing" pixel issue along the edge of certain color combinations.
    Now first, before I get into describing the issue I'm going to note that I haven't taken it apart yet. I plan on replacing the 3300uf @ 100volts cap, assuming this problem is fixable. It smells badly of cigs.
    Now, back to the issue. With certain color combinations, instead of a straight line, certain pixels from one color "dance" into the other. It's worst with black and other colors. Below are some pictures of some color combinations that have this issue:
    And then certain color combinations are fine and 100% sharp:
    It's fine with more colors than it's bad with - for example with that purple background, the only two colors that react are black and that lime green. Those pixels are just statically wrong - they dance around in similar formations shown in the pictures, unrelated to their location on the screen, only related to the colors they're showing. I should note this happens on any input on the TV - HDMI, composite, S-video, etc.
    It's pretty noticeable overall - like on a soccer field, the shadowed portions of the field the pixels are dancing everywhere, probably because it's that green and black combination.
    Now I'm wondering if all this could be fixed by cleaning? Or is one of the boards most likely permanently damaged and need to be replaced? Or is there a specific part that could have gone bad causing an issue like this? If anyone could point me in the right direction I would greatly appreciate it!
    Re: Hitachi 42HDT79 Plasma TV "Dancing" Pixels Issue
    You might be surprised... But, this is normal. It's called "dithering" and it's used to enhance the number of available colours. It's a lot more visible on older TVs like these although in general you shouldn't see it past 6 feet viewing distances. Modern plasma panels have better dithering algorithms which aren't very noticeable. I've never been a massive fan of Hitachi plasma panels for a number of reasons... Wouldnt be surprised if they also have bad dithering
    • darkNiGHTS0
      • Mar 2015
      • 6
      Thanks for the response. I don't think it's intentional because it's even on the system menu. I recorded two videos of it:
      System menu:
      https://www.dropbox.com/sc/tgr5gfpo2...wKPEQvb5PDkK7a
      Original Xbox via component cables:
      https://www.dropbox.com/sc/be1xmfboa...KllIjh8pbvnBYa
      When it's not on a straight line (like the Xbox), it goes everywhere and depending on the color composition of the scene, it makes it very visible from more than 6 feet away. Specifically video games, it's really awful for.
        Oh.... I couldn't see those videos on my phone on the train home... Yeah, that's not normal, dithering is much more subtle. It looks like "mal-discharge" but I have no idea if it can be fixed on a Hitachi panel. (It can be on some other panels.)
        • darkNiGHTS0
          • Mar 2015
          • 6
          Yup, it definitely looks like that.
          https://www.badcaps.net/forum/showthread.php?t=37878
          It's definitely not usable for video games, but it makes make a good sports TV for the basement. It honestly wasn't that bad for soccer from 6 feet away.
          • MDY94
            Hitachi 50HK6100U display issue
            by MDY94
            I own a Hitachi 50HK6100U with a display fault. After some troubleshooting, I've found that removing one tcon cable produces a clear image on the side still connected. Removing the other tcon still provides display output; however, this is a heavily distorted image. With both cables connected, only the top ~25% of the screen provides display output which is still distorted. It's only when both are connected that most of the screen no longer provides output. The attached images show the screen with each tcon cable disconnected, and one with both connected. The red line shows where the display cuts...
            12-18-2024, 12:31 PM
          • navagator
            Hitachi 57F710E Power Issue
            by navagator
            I have a Hitachi 57F710E Rear Projection TV that was working great until 3 or 4 days ago. I came in and tried to turn it on and it was just dead. So, I unplugged it and plugged it back in. Nothing, not even the slight click that it makes when you plug it in. So, I removed the power supply board (It's a vertically mounted board, I believe model HA01312) and inspected it visually for bulged caps or burnt or overheated components, anything that didn't look right and couldn't find anything.
            I noticed on the bottom of the board there was a row of solder joints with voltages printed next...
            11-09-2023, 06:05 PM
          • rounin
            MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
            by rounin
            🛠 Original Issue
            ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
            04-19-2025, 01:18 AM
          • ugamazing
            by ugamazing
            12-17-2024, 07:05 PM
          • Mikeyboy2007
            Hitachi 58HK6100U Strange Issue
            by Mikeyboy2007
            Hi guys i was given this as a freebie. switched it on and screen displays nothing but backlights are on. first thought was panel so i tried some troubleshooting.
            left tab unplugged - right side of screen fine
            right tab unplugged - left side of screen fine.
            i then plugged in left tab while the tv was on and both sides where fine, could access menu, NO SIGNAL splash screen etc.
            powered off with screen ok and powered back on, back to black screen.
            anyone else know what the issue could be ? i have another set the exact same with lines...
            03-29-2023, 05:17 PM
